Author Topic: Yamaha YZ Rear Brake Arm  (Read 1577 times)
Offline Cabmkr
« on: May 21, 2013, 08:53:12 am »
I am going to refurbish the rear brake arm on my 81 YZ250. Of course the bushing on both the frame end and the brake plate end are NLA. I have been going through a bearing listing and search and no luck
Chris
Current rides/projects 75 MX125B, 75 TY250B, 75 Carabella Rally 175, 76 TT500 Ice bike, 78 IT400E 79 CB750F , 81 XS650H Street Tracker, 81 YZ250H X2, 93 DS80
Re: Yamaha YZ Rear Brake Arm
« Reply #1 on: May 21, 2013, 09:02:01 am »
There are 2 things that you can do
1: Cut the end of the brake arm off that takes the spherical bearing & weld on a new 1 that you then bore/ream out to 22mm to take a GE12 spherical bearing, standard is 22.5mm od
2: This is what I've done. I got hold of a YZ490 brake arm(think 250 is same) which has same issue & needed to shorten it by 19mm to fit so I did the same as above except the end piece isn't just round, the end is pushed up inside the aluminium extrusion & a slot cut to weld through. I can take a shot of mine fitted to the bike if you want
Hope that makes sense
