Author Topic: KX 250 1984 replacement clutch plates?  (Read 7882 times)
Offline Husabergpete
« on: May 20, 2013, 06:51:40 pm »
Gents,
To fix a grabby 84 KX clutch. What plates would you recommend?
Thanks Pete and Carl
Offline Stevo17
Re: KX 250 1984 replacement clutch plates?
« Reply #1 on: May 20, 2013, 07:08:36 pm »
They were always noted for their digital clutch... either on or off. I just run genuine plates in mine
« Reply #2 on: May 21, 2013, 02:40:27 am »
Thanks Steve.
So I take it when you put the OEM plates in the clutch is still an on off type.
Ta Pete
Offline SON
« Reply #3 on: May 21, 2013, 05:23:12 am »
If your existing plates are within the recommended range
Scrub the fibre plates clean I use an oldtooth brush
Lightly bead blast the metals
Provided the baskets are ok and the rest of the actuation system is good
The blasting of the metals be they steel or alloy will fix the problem.
« Reply #4 on: May 21, 2013, 07:09:46 am »
Thanks Son, I can do that at work so that will be the first thing to try.
carl
Offline Stevo17
« Reply #5 on: May 21, 2013, 07:46:12 am »
Hi Pete,  yes even with brand new OEM plates it is still on and off... it has a very small operating range.  I was thinking it may be the push rod / lever arrangement that causes it because the 84 500 clutch is beautiful and progressive and it uses the same plates.
« Reply #6 on: May 21, 2013, 10:37:31 am »
I used a late model Honda CR clutch lever & perch, it has a shorter distance between cable nipple and lever pivot bolt (about 22mm compared to 30mm) , the ratio change makes the pull much lighter but also makes the action much more progressive.
« Reply #7 on: May 21, 2013, 07:35:59 pm »
It's only noticeable when I take off normally and slowly, dont notice it on starts. I guess I could put up with it but I will try what everyone has said.
Has anyone tried after market plates as well or just OEM?
And John do you know what year and model the leaver and perch is off?
Carl
Offline Stevo17
« Reply #8 on: May 21, 2013, 07:41:35 pm »
Yeh its the same with mine. Starts are ok but when taking off slowly it grabs and shudders. John's lever change could help I reckon
« Reply #9 on: May 22, 2013, 10:20:16 am »
Carl
Sorry I'm not sure which models, the first lever I bought were just called EZ-pull clutch lever, the advert said they were late CR Honda copies.  They were cheap and broke easily, now I have Moose Racing lever & perches that are 3-way adjustable, so you can adjust the amount of progressiveness and lever resistance to your liking.
« Reply #10 on: May 22, 2013, 08:31:33 pm »
Thanks John
Offline Hardo
« Reply #11 on: May 26, 2013, 02:59:12 pm »
Pete / Carl ...
What did you come up with guys? My 83 KX250 clutch doesn't grab (aftermarket EBC plates and springs), but I need to be popeye to pull the lever ...
Am interested in those EZ Pull lever/perch setups...
« Reply #12 on: June 05, 2013, 07:05:59 am »
so far we've just left them grabby hardo, We can compare them up at glenbawn and ill talk to you about cooming up with a mod
Carl
Offline Hardo
« Reply #13 on: June 07, 2013, 03:39:37 pm »
Team Green meeting?
 ;D
I am going to throw the old STD clutch springs back in mine and see what happens...
Offline Stevo17
« Reply #14 on: June 07, 2013, 04:00:55 pm »
I am running standard springs in mine and its nice and light - no problems with operation apart from a very short engagement throw. You get used to it after a while but it would be a prick if riding vinduro or on trails.
