Author Topic: my long track project  (Read 37720 times)
Re: my long track project
« Reply #15 on: June 04, 2013, 09:08:05 pm »
JUST AN UPDATE
donner motor pulled from staracer roller (going to a forum member)
sorted rear speedway double sided wheel.have sprocket and disc for other side tyre and tube
sorted nos rhs swing foot rest also a rhs gear linkage set up as well.
cant find my nos shocks dont know were they are.
seat  tank(gen esso tank) return oil line back into frame
have a few guards front and back but i like the elstar ones (hint mick)
dirt sheild and wheel disc
making rear engine plates thanks yamaico for the tip,
swing arm at the chromers should have it on friday
lots of work no real time to do it.
wally will get there for our match races this year.new house comes first
jim
454
Offline Slider29
« Reply #16 on: June 06, 2013, 07:24:43 pm »
Keep at it Jim,
Sounds good. Not enough time??.......ain't that the truth.
The older I get the harder I work and get less done!! ::)
 cheers   Mark
Offline SlideRulz
  • Not anti social just anti idiot.
« Reply #17 on: June 06, 2013, 07:36:51 pm »
That's called oldtimers Mark.
« Reply #18 on: June 06, 2013, 09:03:13 pm »
finished the rear engine mounts tonight lunch time in the workshop.will get the swing arm back tomorrow sit the wheels in and bolt it all together.hopfully my dimentions are good then it will be on with the front engine plates.
jim
« Reply #19 on: June 12, 2013, 10:51:23 am »
got the swing arm back today now need some time to put it together.
have a double sided speedway rear wheel need to get the axle out and convert to the pull out axle for the bellini.its a closed ended swing arm so i have to change to a pull out axle i have the gen bellini 1 to use
dirttrack this weekend so no work will be done till next week
jim
454
Offline pancho
« Reply #20 on: June 12, 2013, 04:51:31 pm »
 I've got those XT 4valve bits&pieces ready to bring out for you on the weekend Jim.
Offline JAP 454
  • See Ya at the Skids
« Reply #21 on: June 12, 2013, 04:56:06 pm »
4 valve XT ? wouldn't that be an XT 550, Wal ? circa '82/ '83 Mate of mine put one in a Grasstracker , went like the clappers !
Foss
Offline pancho
« Reply #22 on: June 12, 2013, 05:03:08 pm »
 Yeah Foss, I had the stuff given to me so I'm passing it on, as you do!.
 Looking forward to this Sunday at Nepean Syd. West round 2, great promotion by the Penrith Club. hope the weather holds out.
 I found some more slides to put on later, including one of the great Herb on his old B31 rocket ship at Amaroo.
 cheers pancho.
« Reply #23 on: July 07, 2013, 07:22:22 am »
starting to make engine plates first lot too big by about 20mm
« Reply #24 on: July 17, 2013, 11:37:27 am »
some more pics even have motor sitting in frame now
Offline Sorelegs11
« Reply #25 on: July 17, 2013, 12:13:10 pm »
Looks a tad cramped in there  ;D
Offline Shaun G
  • Sydney, NSW
    • FULL LOAD MOTORCYCLE TRANSPORT
« Reply #26 on: July 17, 2013, 12:20:55 pm »
Looking good Jim.
Haven't got to getting that manifold made up yet. Do you need the original back soon?
Shaun
« Reply #27 on: July 17, 2013, 03:01:07 pm »
when you get it done not yet anyway will let you know when i need it back
jim
Offline pancho
« Reply #28 on: July 17, 2013, 05:41:34 pm »
 Hey Jim, are you going to use the Mark One 'Pancho R.H. Gearshift Mod'
 Refer to 'Foss' for pics of design features!
« Reply #29 on: July 17, 2013, 06:07:59 pm »
no
i am using the kick starter to start the bike
if i want i could send the clutch cover 2 shift rods and 120.00 usd and get sent back a rh gear conv just like the dt1 rt1 and tz250c
gear shift on both sides
jim
