Author Topic: One for the album  (Read 10450 times)
Re: One for the album
« Reply #15 on: May 14, 2013, 07:48:47 am »
Thanks Kev I think I get it now. It's all about the chain tension. You were all over it Tim, I'm just a slow learner! J
Offline JC
« Reply #16 on: May 15, 2013, 09:11:15 am »
It wasn't just to keep constant chain tension. It was to overcome chain torque reaction & supposedly give more drive. Kawasaki tried it too (called Fubar system) in both MX & RR. Duhamel was said to like it for RR (or at least think it had potential). Weinert didn't - couldn't wheelie readily. I think the story was some yanky entrepreneur (perhaps more cynically called a con-man?) made all sorts of claims & Bultaco bought the rights but couldn't get it to work to any advantage.
Offline TooFastTim
« Reply #17 on: May 17, 2013, 10:52:46 am »
Oh yeah. Now I remember Kawasakis efforts.
« Reply #18 on: May 17, 2013, 05:30:12 pm »
What does fubar stand for? J
TM BILL
« Reply #19 on: May 17, 2013, 05:34:00 pm »
Fuct up beyond all recognition
« Reply #20 on: May 17, 2013, 06:23:22 pm »
Ah of course, thank you Bill
« Reply #21 on: May 17, 2013, 09:19:05 pm »
Looks like it's designed to allow the front drive sprocket to be as close to the swingarm point as possible, to overcome the problems created by longer travel and a front sprocket situated a long way from swingarm pivot.
Offline EML
« Reply #22 on: May 18, 2013, 12:25:41 pm »
What about the shock length, are they the worlds longest? Can someone smarter than me (anyone, that is) work out from the drum/wheel diameter how long they are?
« Reply #24 on: May 18, 2013, 02:16:31 pm »
        "Fu-Bar" parallelogram rear suspension and frame as used by Yvon Duhamel at Laguna Seca in 1975.
        1946 Moto Guzzi Dondalino with parallelogram rear suspension similar to the Gilera Saturno design.
Offline pancho
« Reply #25 on: May 18, 2013, 04:38:56 pm »
 I don't see a parallelogram on the Moto Guzzi Dondalino but I do see reduced unsprung weight.
 Also I can see how it would stop wheelies, should work for road racing.
cheers pancho.
« Reply #26 on: May 19, 2013, 07:00:49 am »
To be honest I don't see how the Gilera back end works at all, there is 2 mounting points to the frame each side but no pivots at the axle end or is the lower mount not connected to the frame & instead to a sprung loaded plate under the engine?
Offline euro bikes
« Reply #27 on: July 23, 2013, 03:05:11 am »
Just looked at the Bultaco interesting thing even the front fork legs are from a Matador or Sherpa. My MK9 250 i raced back then had a high pipe the same as that one i got it from Frasers at Newstead, Brisbane,
« Last Edit: July 23, 2013, 02:04:06 pm by euro bikes »
