Author Topic: 86 300 gs burning g/box oil  (Read 3709 times)
Offline gra1961
« on: May 05, 2013, 08:04:02 am »
have an 86 300gs had been sitting for bout 5 yrs due to corroded out water pump housing,replaced and run the bike but was burning g/ox oil,replaced crank seal with gen seal but still smokes badly.drained g/box oil and started and run it for about 30 seconds,no smoke.would be unusual to be sucking it in thru crankcase gasket I would think.anyone think of where else it may be getting thru ?cheers gregg
Re: 86 300 gs burning g/box oil
« Reply #1 on: May 05, 2013, 05:51:43 pm »
Through your case halves between crank area and gearbox. Maybe a faulty gasket.
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #2 on: May 07, 2013, 08:20:40 pm »
Have you burnt out the chamber and silencer yet?
Offline gra1961
« Reply #3 on: May 08, 2013, 07:00:39 am »
no smoke when run without g/box oil cancels out oily pipe .guess i was trying to talk myself out of spliting the cases.motor out she comes.
Offline g465b
« Reply #4 on: May 09, 2013, 09:47:27 pm »
can offer the same advice you offered me-only have two spares and use paper mache,that 300 was mint when u got it
what have u done. cheers
Offline Canam370
« Reply #5 on: May 09, 2013, 11:17:52 pm »
If you aren't sure whether the bikes burning gearbox oil (or if the pipe is full of old oil smoking) put a little Castrol R into the gearbox (with the existing lubricant, not instead of :D) - you'll smell it in the exhaust.
Offline gra1961
« Reply #6 on: May 10, 2013, 06:32:55 am »
thanks grant.where's my compliance plate?
« Reply #7 on: August 13, 2013, 10:37:37 am »
go the crank gasket for sure. try the Castrol r trick, will defiantly confirm or deny the need for a costly time consuming rebuild when all you want to do is ride it.....
