Author Topic: WANTED: 1974 YZ125 or MX125 rear wheel & intake manifold  (Read 1184 times)
ChrisACT
« on: February 20, 2013, 11:29:23 pm »
Does anyone have a 1974 YZ125 or MX125 rear wheel they would like to part with?
« Last Edit: February 21, 2013, 08:18:47 pm by ChrisACT »
ChrisACT
Re: WANTED: 1974 YZ125 or MX125 rear wheel & 1G8 intake manifold
« Reply #1 on: February 21, 2013, 07:21:19 pm »
I'm also after a 1G8 intake manifold.  I believe they were on the YZ125X and the YZ175 among other bikes.
Or any other manifold that will let me put a 35mm carb (40mm spigot) on a DT100 reed block.
« Reply #2 on: February 21, 2013, 08:08:06 pm »
I'm pretty sure 1G8 manifolds have a bigger bolt spacing....maybe the same as a 250.....you might struggle to bolt the sucker up to a DT100 barrell. YZ125X had a 34mm carby and a YZ125C had a 30mm one. You can fit a 32mm carby into a MX/YZ125A intake manifold....they where 28mm I think.
ChrisACT
Re: WANTED: 1974 YZ125 or MX125 rear wheel & intake manifold
« Reply #3 on: February 21, 2013, 08:18:32 pm »
Thanks.  I think you're right about the 1G8.  Too big for what I need.
The DT100 is the same bolt spacing as some of the YZ85s.  The plan is to run a YZ85 V-Force reed block on it with a Mikuni TMX35 running methanol.  If I can't get a carby boot to do this, I can always back it off to a VM28 (which I already have).  That will fit in the carby boot I have.  Will lose a little top end but if it don't fit, it don't fit.
« Last Edit: February 21, 2013, 08:26:17 pm by ChrisACT »
ChrisACT
« Reply #4 on: February 21, 2013, 08:37:21 pm »
I'm thinking that Banshee intakes might do it.  They're the same bolt pattern as the RD250 which is the same bolt pattern as the DT100.
I know there are some guys out there running 34mm - 38mm carbs on Banshees.
ChrisACT
« Reply #5 on: February 21, 2013, 09:04:35 pm »
Yep, I can get Banshee or Blaster manifolds that will handle carbs up to 39mm for this bolt pattern.
And I've found a YZ125 hub.
All good.
