Author Topic: top end swap  (Read 7662 times)
Offline caps 999
top end swap
« on: April 30, 2008, 09:44:46 pm »
question will a it175j top end bolt onto a yz100j bottom end
MUGEN power
Re: top end swap
« Reply #1 on: April 30, 2008, 10:26:04 pm »
Pretty sure the 100s have a shorter stroke, which will bring you undone.
An IT175 top end will bolt onto a YZ125G bottom end (and presumably a YZ125H one too, if you can deal with the un-used water pump).
Offline caps 999
Re: top end swap
« Reply #2 on: April 30, 2008, 10:31:38 pm »
according to climer the 125j 100j and it175 have the same stroke and use the same rod kit
MUGEN power
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: top end swap
« Reply #3 on: April 30, 2008, 10:37:32 pm »
YES YES YES , but you have to change the rod as the pin size is different at the piston end or change the YZ100J crank for a YZ125G crank as they use the exact same crank parts (as YZ100J) but have the correct 175 rod for the conversion. If you look at a 175 barrel and compare it to the 100 you see that they are the same but that the 100 is massively sleeved down.
100J rod is  4V2-11651-00-00
175J rod is  3R2-11651-01-00
Both those part numbers are for 100cc bike 4V2 is YZ100H and 3R2 is YZ100G
Heres what you need....
http://cgi.ebay.com/ebaymotors/Yamaha-YZ100-YZ125-MX125-YT175-Connecting-Rod-Kit-76-79_W0QQcmdZViewItemQQcategoryZ34284QQihZ004QQitemZ140221671536QQrdZ1QQsspagenameZWDVW
« Last Edit: April 30, 2008, 10:47:23 pm by cyclegod »
Ban BLACK rims NOW
Offline caps 999
Re: top end swap
« Reply #4 on: April 30, 2008, 10:41:21 pm »
in this case has any one got a it175 head and barrel ang a good 125g crank
MUGEN power
Re: top end swap
« Reply #5 on: April 30, 2008, 10:54:08 pm »
Check ebay item number 220228807615   Cheers Tim
Offline cyclegod
  • Sunny PERTH W.A
Re: top end swap
« Reply #6 on: April 30, 2008, 10:57:49 pm »
If you're checking with the wreckers ask for prefix 5X8
Ban BLACK rims NOW
Re: top end swap
« Reply #7 on: May 01, 2008, 03:17:15 am »
beware of cut back gears [not full width gear teeth] just the differences i noticed between dt/it 175 gearboxes of the same era,could be abit much grunt for the box to handle
TT5 Matt
Offline caps 999
Re: top end swap
« Reply #8 on: May 01, 2008, 10:52:03 am »
should be rite i checked ypic and according to it the centre cases are the same part# for the yz and it
MUGEN power
Offline cyclegod
  • Sunny PERTH W.A
Re: top end swap
« Reply #9 on: May 01, 2008, 11:04:20 am »
Don't forget to post pics of the finished product (and your grin) after its ready
Ban BLACK rims NOW
Offline caps 999
Re: top end swap
« Reply #10 on: May 01, 2008, 01:21:04 pm »
wiil do ill post a before pic when i get home from work (shhhh) ::)
MUGEN power
Re: top end swap
« Reply #11 on: May 01, 2008, 02:54:49 pm »
Why stop there, why not just bolt a complete it200 motor into it.
Re: top end swap
« Reply #12 on: May 01, 2008, 03:04:04 pm »
or just go and get a 500cc 2 stroke and be done with it.  :D
Offline caps 999
Re: top end swap
« Reply #13 on: May 01, 2008, 03:09:03 pm »
i still wanna keep it lookin like a 100 ::)
MUGEN power
Re: top end swap
« Reply #14 on: May 01, 2008, 05:30:19 pm »
Hey Caps while your the little screamer was here at my place I did happen to measure it re fitting a real engine. Failures Honda 754, Honda XL350, Yamaha XS650, Kawasaki W1/2 650  Ducati 860  ::).. Kawasaki H2 750 and H1 500 triples. Possibles with a bit of work Kawasaki S2 350 triple, Yamaha RZ 250/350 (Mmmm  8)) ,  Honda 500/550 4, Ossa 250, Victa 160cc . Easy fit Yamaha IT175/200 and easiest of Yamaha all YZ100. ;)
« Last Edit: May 01, 2008, 05:39:00 pm by Tim754 »
