Author Topic: A different resto question......  (Read 4034 times)
Tony T
« on: February 17, 2013, 08:05:18 pm »
Not sure where this question should go, but here it is........
I've found an owner's manual under the seat of a bike and the pages are stuck together because of moisture.
Would it work to soak the book in water again and gently work the pages apart, then dry it again?
Has anyone tried it?
Offline Canam370
Re: A different resto question......
« Reply #1 on: February 17, 2013, 08:15:19 pm »
Tony, you could use the same method you've been using to separate the pages of your Playboy collection....... ::)
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #2 on: February 17, 2013, 08:16:39 pm »
I suggest you find a forum frequented by pubescent boys, it's most likely they'll have tons advice to help with this little pickle! Pardon the pun :D :D :D
Tony T
« Reply #3 on: February 17, 2013, 08:19:25 pm »
I knew it!!!!!  >:(
I just knew someone would come up with a comment like that......... should have known it would be you......  you, you, you.... Jawa rapist.....  8)
Offline mustanggrahame
« Reply #4 on: February 17, 2013, 08:21:17 pm »
I'm sure that you had a fair idea of the juvenile responses you would get Tony before you posted this. I reckon your idea would work. Why not try it on a book that doesn't matter first?
Cheers, Grahame
Offline mick25
  • Hunter valley NSW
« Reply #5 on: February 17, 2013, 08:21:30 pm »
You asked for it tony  ??? ;D
maybe a hand held water sprayer like the wifey uses for ironing, or you could try the steam affect  ???
soaking in water maybe to much ???
Offline Canam370
« Reply #6 on: February 17, 2013, 08:23:19 pm »
I knew it!!!!!  >:(
It was consensual I tell you!  All it took was a little top shelf aerostart to get the ball rolling and .........
Tony T
« Reply #7 on: February 17, 2013, 08:29:26 pm »
To be honest, this manual isn't exactly worth a lot of money, but it does look like it's got a sales docket inside as well and it would be nice to save that.
As for the rest of you bastards.............
Offline Rookie#1
« Reply #8 on: February 17, 2013, 08:34:51 pm »
[/quote]
 :D that's why ya love us buddy  ;)
« Reply #9 on: February 17, 2013, 09:01:29 pm »
Put in the freezer .... then defrost it in the sun,  the pages should come apart  ;)
Tony T
« Reply #10 on: February 17, 2013, 09:03:38 pm »
Do I wet it again first, Stewy?
Or just freeze as is?
Thanks mate.
« Reply #11 on: February 17, 2013, 09:13:04 pm »
Put it in the microwave. Same as when you want to open someone's mail. Have to experiment as far as timing goes. J
« Reply #12 on: February 17, 2013, 09:18:14 pm »
Just put it as it is, when you get the pages apart put grease paper ( lunch paper)  between then. If it won't come apart, hit it with a misty spray and try Jerry's method ....
« Reply #13 on: February 17, 2013, 09:45:15 pm »
Jerry beat me to it...try the microwave or if that fails, try steam.
Tony T
« Reply #14 on: February 17, 2013, 10:03:35 pm »
Bloody hell!
Either freeze it or cook it...... decisions, decisions......  :D
