Author Topic: Shock seal dimensions?  (Read 5433 times)
Re: Shock seal dimensions?
« Reply #15 on: February 04, 2013, 09:54:13 pm »
No motomaniac is sure isn't rocket science....
Of course... you're going to go to all the bother of disassembling your shock to only replace the lower seal on the seal assy.... LOL
please....
Matey we rebuild modern shocks all the time and just replace the internal oil seal and external o ring because the seal head is still in perfect condition..
Offline Hardo
« Reply #16 on: February 04, 2013, 09:57:44 pm »
No worries. Each to their own.
I don't pull an engine down and only replace one main bearing.
Ciao !
Good luck Nath.
« Reply #17 on: February 04, 2013, 10:02:15 pm »
Ciao !
Good luck Nath.
A seal head doesn't wear out in 12 months matey, do you put a new set of fork bushes in every time you change the fork seals? Same thing..
Adios!
« Reply #18 on: February 05, 2013, 07:41:53 am »
Anyone got a list/link to the dimensions of shock (not fork) seals?
I'm after 14x46xwhatever and 14x40xwhatever.
As someone said earlier, Jan at Shock Treatment is the go for seals and seal heads..
