Author Topic: Kx 250 1975-76 piston and rings  (Read 10890 times)
TM BILL
Re: Kx 250 1975-76 piston and rings
« Reply #15 on: February 02, 2013, 06:47:15 am »
Big K , Stewy i stand corrected  :-[ 1974 book does list oversize pistons so must have been steel liner . Therefore my 74 must have a 75/76 top end on it .
Wonder why the 74 125 was plated but not the 250  ???
I have had 78 ,79 cyls that have had steel liners retro fitted but i dont like using them, i have got damaged originals and had them replated .
KT 250 was a steel liner to but dont know if pistons fit KXs
The 78 /79 reed top end will bolt onto early cases and does make a big difference , but obviously puts the bike into Evo  ::)
Early cranks will go into 79 cases but not the reverse , 79 has a square edged crank ( apparantly for more weight flywheel effect ) .
Early cases all interchange upto and including 78 KX model and im 99% sure KT as well .
Offline JC
« Reply #16 on: February 02, 2013, 10:34:20 am »
Gents, I can confirm:
74 KX250 was definitely cast iron bore (& non reed)
75 & 76 KX250 definitely electrofusion (& non-reed)
74-75 KX450 was always cast iron bore
KT was always iron bore & uses same piston as non-reed KXs (std is 69.5mm bore IIRC like 74KX)
CR250M Wiseco pistons definitely fit & work in 74-76 KXs & KTs
KX125s were electrofusion from the start (74)
Geoff is correct re electrufusion (except I'm not sure they were carbon rods) - they exploded wires inside the bore at very hi voltage. Diff to chrome plating
« Last Edit: February 03, 2013, 09:24:10 am by JC »
