Author Topic: RM 125 B forks  (Read 3310 times)
Offline suzuki27
RM 125 B forks
« on: April 28, 2008, 07:51:43 pm »
Has anyone got a decent set of RM125B forks.Cash and/or RM parts to trade.Any help much appreciated.
Doc
Re: RM 125 B forks
« Reply #1 on: May 01, 2008, 10:33:04 am »
27, I don't have a spare pair sorry but be it known '78 RM125/250/400C 36mm forks will also slot straight in. Only difference I believe is the spring rate and minor revalving which is minimal difference anyway, the rest is identical. Might make it easier to locate something  ;)
Offline suzuki27
Re: RM 125 B forks
« Reply #2 on: May 02, 2008, 09:40:35 pm »
Thanks Doc,but would they clear pre-78 scrutineering?-at the Classic titles for example.Thats my main worry.
Doc
Re: RM 125 B forks
« Reply #3 on: May 04, 2008, 04:14:20 pm »
yes they most certainly will 27..the C model forks are identical and perfectly legal in every way for pre '78  ;)
my pre '78 RM125 has an A frame and swingarm, A model tank, '78 PE250 forks/triples, '78 C rear shocks, '78 front wheel and A model rear. The engine itself is a '78 C but it too is flow on with little change from the '77,,it's all legal  ;)
« Last Edit: May 04, 2008, 04:19:36 pm by Doc »
rm1976
Re: RM 125 B forks
« Reply #4 on: May 05, 2008, 09:20:54 pm »
hey doc why do you run 78c shocks are they not too long and upset the handling
Doc
Re: RM 125 B forks
« Reply #5 on: May 05, 2008, 11:33:34 pm »
nope it all sits exactly the same when bolted up rm. No obvious gain in the C units only for the fact I had an RM125C and wanted to go pre '78. Keeping it within' regs I fitted as much C stuff as possible to the A chassis. The frames have the same geometry and are pretty much the same in all areas excepting a few little tabs and lugs and of course the steel swingarm instead of alloy of the C. It's like most of my bikes, a piece from here and a bit from there but they all seem to work  ;)
« Last Edit: May 05, 2008, 11:35:23 pm by Doc »
Offline suzuki27
Re: RM 125 B forks
« Reply #6 on: May 06, 2008, 11:03:58 am »
Thanks for that DOC-gives me a bigger pool to look in.
Quicksilver
Re: RM 125 B forks
« Reply #7 on: May 18, 2008, 08:33:43 am »
I have a 125A pair id be happy to trade for parts.
