Author Topic: PD Valves / Gold Valves  (Read 1970 times)
Offline Stevo17
« on: January 24, 2013, 07:10:42 pm »
OK I have a set of gold valves in my 84 KX250 and was wondering if anyone knows where you set the clickers for the original dampers? Do you set the original fork clickers as you would without the gold valves or do you set them at max or min damping? Any advice would be welcome.
Offline motomaniac
Re: PD Valves / Gold Valves
« Reply #1 on: January 24, 2013, 07:16:39 pm »
If you modified the damper rods as per the instructions there should be no need the change the clickers.
Offline Stevo17
« Reply #2 on: January 24, 2013, 07:19:10 pm »
yes the damper rods have been modified, new springs, bushes etc and my forks are ugly...
« Last Edit: January 24, 2013, 07:21:38 pm by Stevo17 »
