Author Topic: 440 gs  (Read 3518 times)
Offline HVA61
440 gs
« on: January 24, 2013, 11:40:11 am »
Anyone using a bing on a GS 440.
if so , could let us know your jetting
main
pilot
needle number
needle jet
slide type
or if using a Mikuni
main
pilot
needle number
needle jet
slide type
Bike is being used for vinduro. I'm having a little issue getting it sorted.
Thanks in advance
Offline flyingdg
Re: 440 gs
« Reply #1 on: January 25, 2013, 03:09:29 am »
I'm at 4500FT and run a 38MM bing on a 74 440.
Main 180 to 175
Pilot 35
Needle jet 276
Needle #5
Slide #2
Offline 09.0
Re: 440 gs
« Reply #2 on: January 25, 2013, 01:14:09 pm »
Main 180 to 175
Pilot 35
Needle jet 276
Needle #5
Slide #2
If that was the same as mine, I would go bigger on the main. It was running too lean on the 98 we have here in Oz. Plus we are pretty much at sea level.
Offline flyingdg
Re: 440 gs
« Reply #3 on: January 26, 2013, 12:20:37 am »
It is the same as your bike. I would think your pilot would be (at sea level) 40 to 45 main 180 - 185 needle jet 280 run the #5 needle and #2 slide. That's what I ran in the bike at sea level.
I built a 38MM bing yesterday for my bike, I had some new parts body, slide, jets I had all the steel parts cad plated. I hate to but it on the bike now that it looks so good.
Offline flyingdg
Re: 440 gs
« Reply #4 on: January 26, 2013, 06:05:44 am »
Brad.....I wonder what that crazy port job you have in that 74 440 maico does to the jetting at sea level with that octane? I’m going to leave the ports alone on this new bike I’m building. I was tired of holding on to that bike.
Offline 09.0
Re: 440 gs
« Reply #5 on: January 26, 2013, 06:04:43 pm »
After changing to the lower compression head and going up a little on the main, it's been great.
