Author Topic: 1978 KTM MC5 250 cc  (Read 16708 times)
Offline Mike52
  • 81 KTM 125 LC
Re: 1978 KTM MC5 250 cc
« Reply #15 on: January 26, 2013, 10:27:30 pm »
Nice  ;)
I have bought stuff off this guy with no problems.
http://www.pentonpartsusa.com/INDEX.htm
Offline motomaniac
« Reply #16 on: January 26, 2013, 10:31:38 pm »
ok no worries but can't do it tomorrow, meeting Iainyz from Tassie and grabbing a lift upto GMC headquarters
« Reply #17 on: January 27, 2013, 09:14:08 am »
The only big change from 77 to 78 is the fork everything else is interchangeable the standard 78 fork is bigger dia 38 versus 35 and well over the 9 inch limit. The frame/engine and rear suspension mounting points are the same
Are you sure? I thought the red/orange 78 frame was quite different from the 77, but maybe I'm thinking of the 79/80 models
I have both models in the shed thou the 78 is enduro , Im not sure but I think it changed every year after that for a while.
Offline ozktm
« Reply #18 on: January 28, 2013, 02:53:13 am »
I asked the very same question back in 2002 on the POG website:
http://pentonusa.org/forum/topic.asp?TOPIC_ID=1269&SearchTerms=78,mc5,changes
Answers here from some US gurus :
Larry Perkins :
 "The 78 MC5 had 38mm Marzocchi forks instead of the 35mm on the 77. The rear shocks were more forward mounted on the 78 than the 77. There was a little more gusset to the swingarm. I think the only motor difference was a single ring piston on the 78 but I could be wrong on that. The bikes looked different. The 77 had a orange tank and the 78 had white. The frame and swingarm on the 78 were orange instead of the 77 which was grey. The forks on the 78 were orange instad of the natural colored 77 forks. The 78 forks were more rigid but the damping was not as good as the 35mm. Later model damping rods will fix this or some tech work on the damping holes. There is probably more but that is all the rememberer is bringing up. Mike Lenz can probably shed more differences light on this one. Mr. Lenz?"
Mike Lenz
"Thats pretty much it except the footpegs are lower and farther forward and I believe they may have pulled the rake in a half degree."
Regards,
Adrian Goold #101
