Author Topic: Zinc Plating  (Read 5634 times)
Offline Bikeaholic
Zinc Plating
« on: January 20, 2013, 12:46:50 am »
Been playing with my new Zinc Plating Kit the I recently bought. It is one of the Janes Kits. I'm having fun with my new toy turning shite into shine  :)
Offline crs-and-rms
  • heaven 23
Re: Zinc Plating
« Reply #1 on: January 20, 2013, 12:55:07 am »
looks good how much  is the kit worth
Re: Zinc Plating
« Reply #2 on: January 20, 2013, 07:45:17 am »
Was wondering what was up with your axle until I looked at the top shot again, might have some issues getting rest of it to blend in properly
maico police
Re: Zinc Plating
« Reply #3 on: January 20, 2013, 08:00:14 am »
Um. I don't think anyone's going to notice the rest of it are they?
Offline Paul552
  • HEAVEN #552
Re: Zinc Plating
« Reply #4 on: January 20, 2013, 09:51:55 am »
Looks nice
Has anyone tried Nickel ???
What do you think is better???
Offline frostype400
Re: Zinc Plating
« Reply #5 on: January 20, 2013, 09:58:23 am »
I have the same kit it is good but a bit time consuming I did 36 spokes and nipples the other week and it took a while but atleast I was able to do the whole job my self plating the spokes and then relacing the wheel.
1971 tm400 and PE's
Re: Zinc Plating
« Reply #6 on: January 20, 2013, 10:07:36 am »
I didn't mean how it looks rather than to not have a step if the plating overlaps
Re: Zinc Plating
« Reply #7 on: January 20, 2013, 11:08:30 am »
Nickel plating is just as easy .... you will note in his pic a thermometer and a clear liquid, you will also need a crock pot or something similar to maintain an even temp.
The difference is zinc is more foregiving and can be easily stripped again where as nickel is a pain to strip back
Offline Bikeaholic
Re: Zinc Plating
« Reply #8 on: January 20, 2013, 11:43:31 am »
No problems just doing the head of the axle. The rest of the axle was in good nick. Not much point doing the whole axle and wasting zinc when it will be lubricated and hidden inside the wheel. From memory the kit was around $360.00 for the 4lt zinc and nickle kit. Came with everything needed other than containers which I bought for around $2 each. I also bought a heating pad (that's it sitting under the container) from the home brew shop which heats the electrolyte to 25-30deg Cel which is the recommended temperature for zinc plating. Zinc plating is the easiest. Nickle plating is a whole lot more unforgiving and a higher temperature needed. Haven't had a crack at that yet.
It is a bit time consuming but handy for restoring brackets and larger bolts, spokes etc which cost a fortune to buy and that is if they are still available too which a lot of the time are not. Smaller bolts, nuts and washers etc I just go and get them from the bearing/bolt shop new. I have a collection of bikes so anything that saves a few $$ with the restorations is handy...and makes the wife happy too  ;D
 You can order the Janes Kits online at www.janekits.com.au
Offline Maicoman
Re: Zinc Plating
« Reply #9 on: January 20, 2013, 01:21:41 pm »
I tried the Jane Nickel plating kit but found the results less than satisfying. I followed the instructions to the later but still had alot of pitting and bubbling of the plating on the surface. I also bought a bottle of the yellow chromate dip but it rubs off quite easily. It is very time consuming wiring every part on and in the end I tossed it away.
    I found a brilliant plater in Woodpark Road, Smithfield called Elite Platers. Myself and another forum member generally drop 2 bikes worth of nuts and bolts in to make good use of the minimum charge of $90.
   They can do just about anything. We've had cast iron kickstart levers, discs, rear sprockets, spokes the lot. They also do metal blackening and the yellow chromate dip.
  I haven't lost any parts as yet even tiny screws which can all be done. For the cost of the kit it just is not worth it in my eyes.
Offline bishboy
  • Toowoomba
Re: Zinc Plating
« Reply #10 on: January 21, 2013, 11:50:30 am »
How does the plating affect the grease nipples on the bolts.  Are they KX suspension strut bolts?
