Author Topic: Splitting late model yz250 crankcase  (Read 3003 times)
Offline Big Scotty
  • Heaven 380
« on: January 17, 2013, 04:44:14 pm »
Has anybody rebuilt a late model 2011 yz 250 2 stroke bottom end? Do you need a puller to separate the cases or are they like my 77 model and come apart easy. Any help appreciated
Thanks Scott
yz400d yz125d yz490k
Offline SUZUKI311
Re: Splitting late model yz250 crankcase
« Reply #1 on: January 18, 2013, 06:17:37 pm »
THey will come apart relatively easily. i always use a crankcase separating tool, obtainable from any decent bike shop (who can get them from MCS, amongst others) and come with a variety of attachments to suit many different bikes. i have seen many a crank damaged by using the old copper hammer trick, it just is not the correct way to do it, even though in a pinch if you are VERY CAREFUL you can do it this way.
Offline Big Scotty
  • Heaven 380
« Reply #2 on: January 18, 2013, 06:51:06 pm »
Thanks for that reply,I rebuilt a kx250 18months ago an had heaps of trouble,I think ill invest in a puller, it sounds like a great investment.
« Reply #3 on: January 18, 2013, 07:40:40 pm »
It is! invest and be happy!
Offline Hardo
« Reply #4 on: January 18, 2013, 09:17:59 pm »
100% agreed. I used to do the caveman method (as many have before me on lots of bikes I have worked on   :-\ ) until I bought a case splitter and Crank puller from Tusk.
Do a search for Tusk Crank puller and case splitter on ebay. Spend the dollars now and never look back.  :)
Offline crs-and-rms
  • heaven 23
« Reply #5 on: January 19, 2013, 01:01:13 pm »
i use a crank case puller to the only way to ,go saves damaging the crank and the cases i also use crankshaft installer on two strokes you should never hit crankshafts
