Author Topic: MR175 CDI  (Read 1889 times)
Offline YUMASTEPSIDE
MR175 CDI
« on: January 11, 2013, 07:27:05 pm »
Anyone know of a CDI backing plate and flywheel that will fit the taper on an MR175 honda?? I think the CR125 and MT125 have the same tapers......also the IT175 but the backing plate is too large   ??? ???
                                Roger
Offline SON
Re: MR175 CDI
« Reply #1 on: January 11, 2013, 08:34:03 pm »
From a memory starting to forget things MR175 and CR125 M2/M3 are the same cases,
Re: MR175 CDI
« Reply #2 on: January 12, 2013, 08:34:12 am »
Yeah, pretty much everything on them is the same, CR125 gasket kits will fit except for head and base gaskets(base gasket will fit if you enlarge the centre)but the MR/MT's are points and the CR ignition will bolt straight up but doesn't have enough weight for the smaller MR crank.
                         Roger
