Author Topic: Pre 60 bikes. What are the choices?  (Read 99881 times)
Offline 09.0
Re: Pre 60 bikes. What are the choices?
« Reply #165 on: January 22, 2013, 07:04:48 am »
Well the 557 has a new home!
Encountered two issues. One interesting and one head fu#k!
Interestingly, when you shift the gears, it activates the clutch so you don't need to touch it. Same feel as a postie bike. Not a centrifugal clutch though.
Head fu#k is the fact that its 1 up three down! Oh no!
« Reply #166 on: January 22, 2013, 09:40:51 am »
Just rotate the gear lever 180° on the spline. 1 down 3 up, too easy  ;D
« Reply #167 on: January 22, 2013, 03:15:18 pm »
or make a heal and toe gear leaver like a postie bike
« Reply #168 on: January 22, 2013, 03:50:47 pm »
I don't know the answer Brad but the old fella looks like a little kid itching to ride his first pushie! I reckon there's a way around that gear lever thing, someone will have an idea....Reece Dengler races a similar bike in the USA so he might know something. Post up on Weedies ;)
Offline Viper79
« Reply #169 on: January 22, 2013, 04:06:39 pm »
You might have to rig up a pivot system on the gear lever similar to what's on late model road bikes which will reverse the shift pattern.
QA50 KO, XR75 K5 Race bike from VMBA days, XR400R1, CRF450R3, RM400T, DR650SE with off road adventure mods, MX360A, YZ400D, YZ465H, IT250H, 1985 Jawa 897 Slider, 2016 Jawa/GM Slider
Offline 09.0
« Reply #170 on: January 22, 2013, 04:51:57 pm »
Yeah that would be the answer. I will give it a run first and see if it messes with my head.
Curly3
« Reply #172 on: January 22, 2013, 05:22:37 pm »
Maybe wear your boots on the wrong feet and hold your tongue the right way. ;) :D
Great score Brad and I'm sure a man of you talents will sort something out, I do have a bit of an idea of what you're up against, going from a conventional " Chooky " gear change to something completely the opposite.
I rode a KX250 and a Hagon Jawa at the same meeting with quite a few interesting gear changes during a days racing.
Offline pancho
« Reply #173 on: January 22, 2013, 05:36:29 pm »
 If that is the only bike you'll be riding it won't take long to get used to it.
Comments- If that uses the kick starter for the gear lever like my 250 did, I found that thriugh the rough stuff at
Moorebank the weight of the lever bouncing up and down caused clutch slip, plus if you had your heel pushed up against the shaft it would disengage the gearshift mechanism. If it is that set up I'd modify.
            Also I would make a retainer plate to ensure the crankcase seals can't blow out. Mine did and went full song into orbit at 'sorbent hill'
 From the look of it it's a factory scrambler model and probably has those mods.
cheers pancho
Offline 09.0
« Reply #174 on: January 22, 2013, 05:42:56 pm »
cheers pancho
You don't know me at all then Pancho!
It has a separate gear lever and kickstarter.
« Reply #175 on: January 22, 2013, 06:21:42 pm »
I prefer 2 smokers, unless considering dual purpose or roadies, but
I really do find this one as pretty as a wet tee shirt or a pole dance comp.
57 AJS
pic is link
Offline bazza
« Reply #176 on: January 22, 2013, 07:11:54 pm »
That AJS is sex on wheels
Embrace patina
« Reply #177 on: January 22, 2013, 08:01:49 pm »
She is kind of pretty,but whats that tank off, Bazza!
« Last Edit: January 22, 2013, 08:04:38 pm by VMX247 »
Offline bazza
« Reply #178 on: January 22, 2013, 08:24:34 pm »
Not sure think pom aftermarket alloy (have seen them for sale Al)   211 with out the indestructable Klub Kevlar sticker looks naked
Dave hows the 211 re build going?
Embrace patina
Curly3
« Reply #179 on: January 22, 2013, 08:46:58 pm »
Now that's more my style, exposed push rod tubes and a big rocker cover, thats real pre60.
