Author Topic: 84 CR 250 Crank  (Read 5797 times)
STW996
84 CR 250 Crank
« on: April 21, 2008, 07:25:48 am »
Hi guys, does anyone know the difference between a 84 and 85 CR250 crank? they have different part numbers so must be a difference, I suspect it will be on the ATAC system which runs off the end of the crank?? We had one of our 84 CR fail the crank at Rocksberg on the weekend and it was going to CD-5 >:(
I have a spare 85 engine and before I strip it was wanting to know??
Shane
Re: 84 CR 250 Crank
« Reply #1 on: April 21, 2008, 09:49:00 am »
pardon my ignorance but can't you shove the 85 engine in the re?  both atac'ers.
STW996
Re: 84 CR 250 Crank
« Reply #2 on: April 21, 2008, 10:15:11 am »
Yeah both ATAC'ers Twisty but are differnet types of ATAC systems (85 is like the 84 125 with the extra valve body in line with the exhaust port, different back mounts 84 has the mounting bracket bolts to motor and the 85 is just straight through swing arm.
Looking in the Clymer book and the pickup off the crank looks the same but the 85 has the same part number as the 86 which is different (go figure). Going to pull the engines down tonight so will let you know the outcome for future reference.
Shane
Re: 84 CR 250 Crank
« Reply #3 on: April 21, 2008, 05:54:24 pm »
Shane , i have a spare CR250RG 1986 crank i got some years back at a wreckers if that helps you out.
i would not know how good the rod/big end is though? i can take a pic and send it to you if this helps.
STW996
Re: 84 CR 250 Crank
« Reply #4 on: April 21, 2008, 08:56:16 pm »
Thanks Hoony will get back to you on that, we have desided to remove the metal plate covers from crank and re-install as is with new rod. Alan at Serco can do this for us post hast and all should be good. Will lose a bit of down low power but it is the bike my brother rides and he has a good 10 KG less than me to cart so will even things out. Hey Hoony will get you to take some shots and PM me if you can as I would like to see the difference in cranks as lots of RG cranks for sale and no RE.
Thanks mate for the help the fleet should still be at seven for the weekend.
Shane
STW996
Re: 84 CR 250 Crank
« Reply #5 on: April 23, 2008, 01:40:55 pm »
Have just been to Serco to pick up crank Which is a Wisco copy of the Honda 88 model crank looks all the same as the 84 cannot see any differences and was only 330 dollars brand new complete with mains and little end roller!! off to fit now so will keep all updated.
Shane
Re: 84 CR 250 Crank
« Reply #6 on: April 23, 2008, 02:48:09 pm »
That's a bargain. will send you some shots Shane No worries.
Re: 84 CR 250 Crank
« Reply #7 on: April 23, 2008, 04:20:06 pm »
Shane,
i have emailed you some Dimensioned shots of 250RG crank for future reference.
STW996
Re: 84 CR 250 Crank
« Reply #8 on: April 23, 2008, 04:54:28 pm »
Thanks mate, brother is home fitting now and has done a mockup and all is good. Worth telling the boys out there about this one because it looks like and 250 crank 84 to 97 are interchangable ;D
Shane
STW996
Re: 84 CR 250 Crank
« Reply #9 on: April 24, 2008, 05:57:39 am »
Well Hoony all a goer we installed the engine back in the bike last night. Keep in mind what I said about the cranks and tell others as 330.00 for a crank ex Serco (brank new with 2 x main bearings and a little end bearing) is better than one for a 100 on ebay that would still need a 200 dollar rebuild!!!
Shane
Re: 84 CR 250 Crank
« Reply #10 on: April 24, 2008, 07:13:26 am »
will do shane, i have a mate with a 250RE that dropped the bottom end off about 7 years ago , i have been pushing him since to get it going and come and play with the boys.
Offline crs-and-rms
  • heaven 23
Re: 84 CR 250 Crank
« Reply #11 on: April 25, 2008, 10:10:29 pm »
do you have a part number for the new crank ive got an old re that needs a crank thanks ;D
STW996
Re: 84 CR 250 Crank
« Reply #12 on: April 29, 2008, 06:25:23 am »
crs-and-rms the docket item code (this is from Serco receipt) is WPC101 and discription is Honda crankshaft assembly CR250 92-01.
Has worked a treat in ours ran great all weekend and outdid the rider!!
If more info required please email
Can buy from Serco Capalaba 07 3823 3833
Shane
Offline crs-and-rms
  • heaven 23
Re: 84 CR 250 Crank
« Reply #13 on: May 10, 2008, 05:16:42 pm »
thanks shane i will give them a ring regards alec
