Author Topic: White Brothers DR400T  (Read 106035 times)
GT43
Re: White Brothers DR400T
« Reply #120 on: February 04, 2013, 11:49:44 pm »
I think I know what your getting at Mick. Thanks for that info.
Does the Flat slide need to be jetted ?
I use a flat slide pumper carby off a DR600. works great on the DR500 and no flat spots.
Handy to know as well, appreciate it.
Offline DR500
« Reply #121 on: February 05, 2013, 09:51:28 am »
It's off a 1984 DR600, 40mm mikuni.
Offline DR500
« Reply #122 on: February 05, 2013, 09:52:27 am »
40mm mikuni
DR Fan
« Reply #123 on: February 05, 2013, 10:04:00 am »
Do you have any jetting specs for the DR 600 carb onto the 500.
Offline aehunger
« Reply #124 on: February 23, 2013, 06:21:19 pm »
Hi All,
Shocks on my DR are flogged strictly spring only action making for a ride with zero damping. What is best value for money in terms of replacement units. I will be honest ive got two kids so time riding is very limited therefore dont need top of the line gear.
Kind Regards
Alex
« Reply #125 on: February 23, 2013, 06:36:11 pm »
Contact ....Hone Heki, he knows of a place local that does rebuilds.
Offline aehunger
« Reply #126 on: February 23, 2013, 07:00:26 pm »
Thanks I think...Although I read in my Clymer manual the units are disposable or is there new technology that make that statement untrue.
Alex
Kind Regards
Alex
« Reply #127 on: February 23, 2013, 07:30:43 pm »
Alex.....   new technology that make that statement untrue.
« Reply #128 on: February 23, 2013, 10:07:26 pm »
buy some yss shocks as there going to be more advanced then your 1980 std rebuilt shocks and wont be that much more in $$ value,youll even get springs to match your weight and riding style ; ;)
Offline cloggy
« Reply #129 on: February 24, 2013, 01:01:59 am »
 I'd put 16.5" shocks on. The bike turns better and is still stable I'd check YSS against the price of a rebuilt set before you decide
 There is a second hand shock that works really well on DRs but I don't know if you got this military model down under. It's the Armstrong 500/Harley350 Rotax. I have a set of these on one of my DRs, they are 16.5" Ohlins, excellent quality , adjustable and the spring rate is just about right.
Offline Marc.com
« Reply #130 on: February 27, 2013, 01:38:16 pm »
Just picked up this one ::) couldn't help myself, have Simons and White Bros swinger, OEM lights and odo in my war chest to go on
TM BILL
« Reply #131 on: February 27, 2013, 01:46:22 pm »
Marc you may as well grab this one too  :)
http://www.trademe.co.nz/Browse/Listing.aspx?id=566948325
Offline Marc.com
« Reply #132 on: February 27, 2013, 01:51:49 pm »
market is saturated with them..... plenty of candidates for GMC ftrame kits
Offline aehunger
« Reply #133 on: March 03, 2013, 01:15:41 pm »
How does the front end come away from the frame on the DR400? I can see a single bolt at the top of the triple clamp but am unsure about the remaining assembly method. Would appreciate any pointer on this topic. Also would like to know of the availability of piston ring sets in NZ.
Kind Regards
Alex
« Reply #134 on: March 03, 2013, 04:52:05 pm »
Ok ...undo the bolt you have mentioned  , then take out the pinch nut and bolt just below it .... then undo the pinch bolts LHS & RHS that hold your fork tubes - do the same with the bottom triple. You will need to elevate the bike a bit to allow the tubes to slide thru the triples....... are you with me  ;)
Next there is a lock nut with slots in it just above the dust seal ( top of steering head ) undo that and make sure you hold the bottom triple at the same time to stop it falling on the floor  ;)
http://www.alpha-sports.com/suzuki_parts.htm
