Author Topic: yz 125 e 2k6  (Read 4243 times)
Offline Jim
yz 125 e 2k6
« on: November 08, 2012, 05:38:52 pm »
Gents...After a engine gasket set, upper and lower con rod bearings,rings, for our little project to get it started.since u people have been doing this for a while, is there somewhere in aus i can get these parts or do i have to go o/s.Havent measured up yet but all looks std ....cheers....jim...
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: yz 125 e 2k6
« Reply #1 on: November 08, 2012, 05:57:36 pm »
Yamaha shop for the gaskets.
Ebay for the rod kit.
Your local bearing shop for all your engine bearings.
"flat bickie"
Re: yz 125 e 2k6
« Reply #2 on: November 08, 2012, 06:32:19 pm »
You'll probably find one bearing can't be bought from the bearing shop. Look o/s for it as yamaha will charge you $80 for a $10 bearing
Offline Jim
Re: yz 125 e 2k6
« Reply #3 on: November 08, 2012, 06:35:58 pm »
thanks for the info vandy010 thought it might have been a bit more difficult than that given its age .will give it a go...cheers...jim...
Offline YZ250H
  • Back in QLD Baby !
Re: yz 125 e 2k6
« Reply #4 on: November 09, 2012, 12:22:33 pm »
Is that the needle roller that takes the clutch actuator ?
Stupid Yamaha and their bodgy bearing sizes  >:(
Offline vandy010
Re: yz 125 e 2k6
« Reply #5 on: November 09, 2012, 01:24:20 pm »
it was a while back now that i did my 125F but from my vague memory,
the Yammie bearing is 11mm wide and the bearing shop can do one the same but 12mm wide.
after measuring it all up, the 12mm bearing fitted.
2 seasons on all is good ;)
"flat bickie"
Offline Viper666
    • Ballarat Rovers MCC
Re: yz 125 e 2k6
« Reply #6 on: November 15, 2012, 03:08:38 pm »
All roller bearings, bar the gearbox needle rollers & conrod bearings, can be bought from bearing joints. OEM are better for the crank but 4X as expensive, if you use aftermarket ask for C3 bearings for more clearance. Gearbox aftermarket ones are fine.
Conrod kits are plentiful on ebay but look for IT 125/175 about pre 81 & DT125/175 right up to late 80's All the same a & way cheaper.
Yamaha shop for the gaskets but aftermarket kits are available on ebay pretty cheap.
Viper666
Offline Jim
Re: yz 125 e 2k6
« Reply #7 on: November 15, 2012, 05:40:40 pm »
thanks viper done a bit of looking thru manuals and head scratching and came up with the same as u mentioned.obviously a lot i dont know about the bike,like y would someone grind away the cutaway on the back of the piston,some sort of performance enhancer i should imagine,but we r getting there...cheers.... jim..
Offline Jim
Re: yz 125 e 2k6
« Reply #8 on: November 15, 2012, 08:05:23 pm »
just cleaned up the piston has 25 stamped on the crown near the arrow and measures 56.179mm with a mic .i am assuming the, 25 would b first o/size...?would this b right,although have been known to b wrong before just ask the minister for war...cheers..
