Author Topic: Wanted: 1979 YZ 400 f piston and rings  (Read 12752 times)
Offline Yamahaha
  • Melbourne Vic
« on: October 23, 2012, 12:37:22 pm »
Need some help guys, following a engine malfunction at ravenswood viper on Sunday my YZ is in need of a top end rebuild. I need a 1st or 2nd oversize piston kit, the bike is still a virgin bore amazingly after all these years. They appear to be very scarce.. I can get a 426 OW kit but it means boring the standard barrel to death which I am not particularly keen to do.
Any leads or ideas would be greatly appreciated. MARK VIPER 73
YZ 250 modern, YZ 125G, YZ 125E, IT 400D, IT 175G x 2, YZ 400F CR250re,  2012 yz450fse Service Honda CR500AF.   Viper #73
Offline motomaniac
Re: Wanted: 1979 YZ 400 f piston and rings
« Reply #1 on: October 23, 2012, 01:57:12 pm »
only old stock , because they are an odd size nobody does aftermarket , there were some on ebay us recently .
where can you get an ow kit ? how much?
Offline Yamahaha
  • Melbourne Vic
« Reply #2 on: October 23, 2012, 03:11:19 pm »
I'm guessing you found the ow kit Brent, cheers
Offline motomaniac
« Reply #3 on: October 23, 2012, 03:27:47 pm »
this will work if you dont want to go to 85mm bore ,the only difference is the piston has ports on the inletside instead of a cut away.
http://www.ebay.com/itm/1979-YAMAHA-IT400-1ST-OS-0-25-PISTON-PN-2X8-11635-00-00-/180533312816?hash=item2a089fbd30&item=180533312816&pt=Motorcycles_Parts_Accessories&vxp=mtr
Offline Billet YZ
  • Melton Victoria.
« Reply #4 on: October 23, 2012, 04:43:23 pm »
Hi Mark,
            what is the actual bore size you will need. I have a piston to suit 82mm bore if that helps. Peter.
Offline motomaniac
« Reply #5 on: October 23, 2012, 04:52:36 pm »
Hi Mark,
yer they are 82 mm , only 79 yz and it 400's
Offline Yamahaha
  • Melbourne Vic
« Reply #6 on: October 23, 2012, 05:17:22 pm »
Yeah 82 Pete, is it 82 exact or .25 or .50 etc bigger than 82? It was standard but now needs to be first maybe 2nd over
Offline Billet YZ
  • Melton Victoria.
« Reply #7 on: October 23, 2012, 06:35:21 pm »
82.00 mm standard bore size. Let me know if it helps.
« Reply #8 on: October 23, 2012, 08:02:37 pm »
The 426 kit just uses the YZ400 D/E model piston. You can bore the F model out and use those pistons, it was a popular mod in the day.
Offline Yamahaha
  • Melbourne Vic
« Reply #9 on: October 23, 2012, 09:19:58 pm »
Does anyone know if using the 79 it 400 window style piston or the earlier 77-78 piston affect performance or port timing?? What a bugger of a model bike...
Offline motomaniac
« Reply #10 on: October 23, 2012, 09:37:23 pm »
no it doesn't . It is an 85mm bore but not the same piston. I bought Landmans spare OW stuff after he'd finished with the F.
Offline motomaniac
« Reply #11 on: October 23, 2012, 09:46:53 pm »
The 79 IT is the same in every dimension except for the intake side. it will make the bike a bit less explosive like an IT and will also minimise the famous Yamaha rattle . It was a common swap back in the day .There is an article on a MX400B  with this swap in an early ADB .
The earlier 77/78   85 bore x 70 stroke piston will make your bike run like a gutless 250.
Its a great bike .You just have to get to know them.
« Last Edit: October 23, 2012, 09:55:48 pm by motomaniac »
« Reply #12 on: October 23, 2012, 10:08:18 pm »
What i'm saying is you can use the D/E YZ400 piston in the F, Gaythorne Yamaha ran them in Andrew Bailey's YZ400F in '79... Ask him
Offline D project
« Reply #13 on: October 23, 2012, 11:31:51 pm »
Told you someone would be able to help you out ;D
Offline yamatragic
« Reply #14 on: October 23, 2012, 11:55:19 pm »
  :o :o :o :o :o :o :'(
