Author Topic: 1973 250 Clutch Plate specs ? Sprockets & now shift shaft !!!!  (Read 16006 times)
Re: 1973 250 Clutch Plate specs ? Sprockets & now shift shaft !!!!
« Reply #15 on: October 20, 2012, 09:28:23 am »
Can you explain or show difference between the 4 & 5 speed mechanisms, may explain why I have issues with overshooting 2nd gear on my 380 when downshifting
Offline VMX60
« Reply #16 on: October 20, 2012, 12:56:21 pm »
Pete
A 13t or 14t should be all you need for a 250cc 5 speed  spot on Tony
SHAFTS
BTW this is the difference between a 4 and 5 speed shaft. 5 top 4 lower.The stop plate is 2mm wider on a 4 and theyre welded to the shaft. And the quadrant arm of the 4 has 3 notches, the 5 has 4
To replace the shaft means spliting the cases
« Last Edit: October 20, 2012, 01:11:03 pm by VMX60 »
« Reply #17 on: October 20, 2012, 01:30:16 pm »
Thanks for that, may be able to check mine out when I change the oil next
Offline Husabergpete
« Reply #18 on: October 23, 2012, 09:45:09 pm »
Chaps, would anyone have a spare second hand rear sprocket bolt and nut????
Pete
Offline shortshifter
  • Sunshine Coast QLD
« Reply #19 on: October 24, 2012, 09:44:50 am »
Great explaination and picture 60 :)
« Reply #20 on: October 25, 2012, 09:32:31 pm »
Shortshifter, thanks for the heads up. the spline is a bit twisted as well. Better to do it right the first time I reckon. Chasing one down
Pete and Carl
