Author Topic: YZ 250 A  (Read 3003 times)
Offline allan hughes
YZ 250 A
« on: October 02, 2012, 07:28:02 am »
YZ250A FRONT FORKS
TO FIT TO YZ125A
I HAVE BEEN TOLD THIS IS ABLE TO DONE
ANY DRAMA THANKS
Re: YZ 250 A
« Reply #1 on: October 02, 2012, 07:35:18 am »
You need YZA/B 250/360 forks, tripples, front wheel, brakes, brake cable.....just take the whole lot out of your 250.....you will need longer shocks aswell to make it work properly....360mm, cheers John.
Re: YZ 250 A
« Reply #2 on: October 02, 2012, 11:19:45 am »
Yep. DT or MX250/360 parts are also a huge improvement over the stock 125 parts, while being much cheaper and easier to find than YZ250/360A stuff.
YZ125C bits also work and are legal - the upper tubes are the same as YZ-B, while the lower legs are the same as DT/MX-A. If you're a real fuss pot, there's a slight, non-performance difference between the YZ125C lowers and the earlier parts, but it would take a train-spotter to pick it. And a vindictive jerk to protest over it.
Re: YZ 250 A
« Reply #3 on: October 02, 2012, 11:36:26 am »
I fitted a complete MX250 front end including triples and the wheel to my MX125 with no problem, it's a bolt on.
« Last Edit: October 02, 2012, 12:03:32 pm by firko »
Re: YZ 250 A
« Reply #4 on: October 02, 2012, 12:25:47 pm »
you just need to fit the 34mm triples ( any yamaha model ) and fit what ever you like MX, YZ or what have you easy access to
Re: YZ 250 A
« Reply #5 on: October 03, 2012, 07:27:23 am »
YZ125 A AND COMPLETE YZ250A FRONT END
DELIVERED TO IVAN AT TFB TODAY
THANKS AL
