Author Topic: Ossa timing  (Read 2630 times)
Offline matcho mick
    • Moto Tumbi
Ossa timing
« on: September 29, 2012, 07:29:31 pm »
my 73 explorers ignition had a dummyspit at CD9,put a spare on,but have run out of slot adjustment on stator plate at 2.2mm before TDC,clymer manual gives ignition timing @ 2.75- 3 for 71-72 models,(i'm assuming 73 model would be the same),both are 5 wire stators/humongus rotors,the timing location pinholes is left of centre on the replacement stator,my original is dead centre on the "trigger" plate,(both rotors are centrally indexed??),WTF??,anyone come across this "problem",i realize i could extend the slots,but not too a desirable fix as plate has wider stepped sections after narrow slots,cheers mick
Offline matcho mick
    • Moto Tumbi
Re: Ossa timing
« Reply #1 on: October 14, 2012, 10:53:23 pm »
oops,doh,earlier tonite i replaced with original dud stator (which i had indexed with dash against crankcase) to see where motor was originally timed,it read 1.2 btd,wtf,have been thinking about it since,it fugging just dawned on me,(up the shed & checked) my dial guage is in 1",not fugging metric duh!!,i bought it for doing cranks,sooooo 1.2 (120thou)is pretty close,idiot me forked meself with science ::), :P
Offline cemotobull
Re: Ossa timing
« Reply #2 on: October 14, 2012, 11:45:50 pm »
You should be using a cigarette paper and a pencil!!! I was hoping you got it sorted!
