Author Topic: More Billet Stuff.  (Read 2230 times)
More Billet Stuff.
« on: September 22, 2012, 02:30:29 pm »
Here's a list of more trick stuff..... YZ/MX A/B/C..DT 125/175...TY175 gearchange repair bush $30
RM125 N/T front wheel spacer $12
322/1K7 Yamaha front wheel spacer$12
  Alloy fuel tank tap repair spigots...L to R....Maico 16x1.0.....TY250.....YZ A/B/C.....YZ A/B/C screw on damaged thread....OW Yam style....Suzuki RM A/B...PE B. Various prices....pm
 Suzuki seat mount...fits A/B/C and will do TM if you remove the old one and bolt these to the steel base. $33 pr
  RM250/370 A/B engine mounts....RM125 A/B/C engine mounts $33 pr
 RM 125 A/B Brake torque arm....will fit TM125....RM250/370 A/B brake torque arm. $45 each
I also have YZ125A rear axle spacers $12 and RM125A rear axle spacers $12
All these parts are garranteed to make you faster or you can have an extra big mac and not worry about it!! ;D...ph 0412747729
« Last Edit: September 22, 2012, 04:35:21 pm by Davey Crocket »
Re: More Billet Stuff.
« Reply #1 on: September 27, 2012, 04:42:53 pm »
those YZ tank threads are y7ou saying you screw that section onto the exsisitng spigot and fix inplace ?
« Reply #2 on: September 27, 2012, 05:36:20 pm »
The 4th one along Freaky you can screw up onto the original thread with some devcon epoxy and then screw the fuel tap onto that.....the fuel tap just sits a bit lower. The others are all weld on and when I repair a tank they automaticaly get one.
« Reply #3 on: September 27, 2012, 05:52:53 pm »
Dave I would be interested in 2 of the screw on yz A/B/C types . how much $ . Iain
« Reply #4 on: September 27, 2012, 06:23:15 pm »
$20 each Iainyz plus post which wouldnt be much.
« Reply #5 on: September 27, 2012, 11:19:35 pm »
Ill go two then Dave , If you pm me with your banking details Ill sent to your account . Iain
