Author Topic: Bing advice (now with a photo you can see)  (Read 2190 times)
Offline Gippslander
« on: September 09, 2012, 02:24:19 pm »
 Hi, have a 72 CR450 Husky and a 74.5 250 MX KTM, both with Bings, both start ok and run well, have been out of action for a while with a smashed shoulder, just spending some time getting the bikes ready for som very slow tryouts :-)
Pulled the carbys, to give them a good clean out.
The main jet and emulsion tubes are different -- see photo -- the top one is from the 450 Husky, bottom one from the 250 KTM.
The 74.5 KTM has a cutaway that faces "downstream".
Here's the two Questions...
Are both setups ok or should I order some parts to "upgrade" the 72 Husky set up?
Where in OZ stocks the usual rebuild parts for Bings.
And I know there will be a few who will advise me to get a Mikuni, yep OK, I know they are good but previously I have not been able to get them running spot on (on a 73 CR250 Husky) and I am a bit shy about trying again when the Bings run so well.
« Last Edit: September 09, 2012, 07:06:13 pm by Gippslander »
Offline oldskool
Re: Bing advice
« Reply #1 on: September 09, 2012, 04:39:38 pm »
don't know if he will have them but you could try bk performance he is at ormiston near cleveland in queensland.
http://www.bkperformance.com.au/
cheers.
Montynut
Re: Bing advice (now with a photo you can see)
« Reply #2 on: September 09, 2012, 07:19:34 pm »
Best people I have found for Bing parts are
http://bingcarburetor.com/
They are slow to deal with as they really want to supply the exact parts. Overhaul kits for each kit is the go. The major overhaul kit includes jets.
I found it best to actually ring them.
Les at VMXunlimited has some parts
Offline ozktm
« Reply #3 on: September 14, 2012, 09:44:36 am »
Hope this helps, some helpful info from back in the day.
Regards,
Adrian Goold #101
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #4 on: September 17, 2012, 09:44:03 am »
try Bert Floods imports  they still had Bimg parts for the Rotax areo engines last time i spoke to them ask for David or Gary
