Author Topic: Engine case RM250N  (Read 4321 times)
Engine case RM250N
« on: April 10, 2008, 11:22:37 am »
I am in need of a left hand side (ignition side) engine case to suit 1979 RM250N. Cash or have parts to trade for most makes/models.
Re: Engine case RM250N
« Reply #1 on: April 10, 2008, 04:06:42 pm »
Good luck mate I've been chasing the same for a  T  ( Dreeded chain rash )
Quicksilver
« Reply #2 on: April 10, 2008, 04:11:57 pm »
I can tell you RM500 case's are still avialable new for a massive $1200. Maybe are 250 cases are avialable too at a lower price. Worth checking out with your Suzuki dealer.
Offline Billet YZ
  • Melton Victoria.
« Reply #3 on: April 10, 2008, 08:21:16 pm »
Hi bigk, i take it you have a damaged left hand case, is it beyond repair ?. I have repaired a lot of cases and you would struggle to pick it. Let me know if this is an option for your project. Peter.
« Reply #4 on: April 10, 2008, 09:25:40 pm »
It's a bit far gone to repair in that virtually all the clutch arm housing section is gone. I don't have the peice that's missing. I have found plenty of PE250 cases, are there any major differences other than the ignition housing bolt pattern?
Offline Billet YZ
  • Melton Victoria.
« Reply #5 on: April 10, 2008, 09:47:42 pm »
Most of the cases i have repaired have had the same damage as yours, with those i built up the area that is missing then remachined it to suit the seal / shaft diameters as per original. Peter.
