Author Topic: CZ400 Question  (Read 3138 times)
Offline VMX Andrew
CZ400 Question
« on: July 21, 2012, 11:01:47 am »
Got leaky fork seals and would like to put some new ones in.
Having a bit of trouble taking the inners out of the top clamp.
Have you gotta screw them out from the bottom or tap them out from the top.
It looks like someone has already had a crack at trying to tap them out from the top
cause there is some minor damage to the inside top of fork.
Unsure on what to do and a little bit embarressed,never seen anything like it. ;D
My owners manual arrives next week but would like to knock it over this weekend..
Any info on this subject much appreciated.
Thanks Andrew
albrid-3
Re: CZ400 Question
« Reply #1 on: July 21, 2012, 11:13:20 am »
If you are taking the forks aparts, their is a allen head screw (bolt) at the bottom of the forks where the axle is, then you need to undo the fork caps remove the inners springs, and get the longest
screw driver you can buy, make sure the flat end is wide enought, put that into the fork tube and lock the inner and turn the allen head bolt.
Offline VMX Andrew
Re: CZ400 Question
« Reply #2 on: July 21, 2012, 11:17:50 am »
Sooo there is no need to take the inner out.
But can it be taken out of that top triple clamp ???
albrid-3
Re: CZ400 Question
« Reply #3 on: July 21, 2012, 11:29:35 am »
call me on 0405534146cheers David
Offline Noel
Re: CZ400 Question
« Reply #4 on: July 21, 2012, 01:12:50 pm »
As Dave said,
allen screw up from the bottom, a rattle gun is good here,
then slide bottoms off.
the top triple clamp is a taper fit on the fork tube, a little heat may be needed, but if you do not need to remove them it is goo that there are tight, leave them alone
http://www.czmadness.net/,
tech stuff here
Noel
« Last Edit: July 21, 2012, 01:15:36 pm by Noel »
Offline VMX Andrew
Re: CZ400 Question
« Reply #5 on: July 21, 2012, 07:21:34 pm »
Its all good got the bottom leg off and left the top in the triple clamp.
New seals and dust covers are in place.
Tomoz ill put it all back together and everything will be fine.
Thanks to Noel and 46m for your input, really appreciate that. 8)
Cheers Andrew
albrid-3
Re: CZ400 Question
« Reply #6 on: July 21, 2012, 07:39:15 pm »
Your Welcome Andrew.
