Author Topic: Big thank you to TM Bill  (Read 1528 times)
« on: June 20, 2012, 04:22:40 pm »
Sorry been waiting to get the nats out the way before looking at this one.
But a big thanks to TM BIll for posting a whole lot of parcels over the last couple of months.
Dragged them out last night to see what there is and make a started  ;)
THANK YOU bill for all your hard work and effort to get this in the mail.
Now if anyone can pick up a tub from Taupo and drop it to Auckland, then i can probally fire it up real soon ;)
thaks again TM  :-*
TM BILL
Re: Big thank you to TM Bill
« Reply #1 on: June 20, 2012, 04:54:15 pm »
No worries Freaky  :) send me details of where the motor needs to be dropped off . If somones going that way i will send it with them .
You should post a pic of the bike , its a real cool piece of kit and attracted a lot of atten while it was in my short term custody  ;D
Joan wanted to take it around the MX track when he and Brad were here at easter.
I was sceptical of your post me the bike plan but although the motors still here it seems the plan is coming together  8)
« Reply #2 on: June 27, 2012, 03:24:31 pm »
yep bill, its prity much together but think im still missing some bits.  looking at the post reciepts and what i sent you, im about $250 out so im hoping there is another parcel on its way ? im short throttle, throttle cable, carby, front tyre, oil catch can( must come off motor or it will snap the cases) and what ever else i cant see.
But im up 2 rubber washers, which i have no idea where they came from.
The best part was the 2 good pictures i had of it, just had to zoom in on the laptop as i was putting back together so easy as piss.
« Last Edit: June 27, 2012, 03:48:44 pm by Freakshow »
« Reply #3 on: June 27, 2012, 03:37:58 pm »
Question do you remeber if the tank used grommmets inside the frame gusset on the tank front mount ? seems there needs to be some packing to keep the tank from moving side to side.  i have also put a steel sleeve inside the rubber mount so the bolt goes through it and picks up the 12mm to the 10mm bolt and also to frame out the gusset from crushing in. which makes me wondr if that and the side washers are missing.
Normally there a inner/outer 1 piece rubber with a steel sleeve, but looks like this bike is home schooled ( used bunnings fittings) so maybe not how he set it up.  Same with the engine washers (should be cups) and bolts are wrong.  But all in all should be a good bike if it comes in at budget, but it might go over some
« Last Edit: June 27, 2012, 03:49:31 pm by Freakshow »
« Reply #4 on: June 27, 2012, 03:44:44 pm »
YEp Motor boxed and sealed in a RUBBERMAID TUB to : ( the oil can has to unbolt from under the motor if it wasnt mailed)
PACK & SEND Albany - North Shore
Address 33D Constellation Drive
Albany 0632
Monday – Friday, 8:30am – 5pm
Saturday, 9am – 12pm
Phone +64 (09) 476 6467
Fax +64 (09) 476 6488
Email [email protected]
and shipped to Pack and send Glenelg,
Michael Gibbons
Shop 2, 694 Anzac Highway
GLENELG
SA 5045 Australia
Email: [email protected]
« Last Edit: June 27, 2012, 03:48:15 pm by Freakshow »
