Author Topic: fibre clutch plates for '87 350 2 stroke  (Read 2228 times)
Offline kitakitsune
« on: June 11, 2012, 09:16:27 pm »
G'day guys, can anyone tell me if the fibre plates are the same for '87 - '89/90 350's and 500's. Barnetts clutches only list '89 plates. Wouldn't want to get them and find they don't fit. Better yet, does anyone know a local supply for these clutch plates?
Cheers Chris.
Go no-where in your mind, and
you are now-here.
Offline jurado
Re: fibre clutch plates for '87 350 2 stroke
« Reply #1 on: June 20, 2012, 12:43:25 pm »
The larger clutch disks are for the 90-96 model, and dimensions are:
- inner diameter 120 mm
- outer diameter 139 mm
- outer diameter incl pins 149 mm
Pre-90´s model disks are smaller, with dimensions as follows:
inner diameter 112 mm
outer diameter 133 mm
outer diameter incl pins 143mm
Yours should be like these lasts ones. So, to me sure, please ckeck with André Horvath ([email protected]), from KTM Klassiker.
