Author Topic: Suzuki TM250 mag cover  (Read 16421 times)
Re: Suzuki TM250 mag cover
« Reply #15 on: April 05, 2008, 08:23:37 pm »
Geez louise :o
 did he find that in the barn or under it?
 What did you do to the shock mounts on your baby Doc?
I had an L model  that wasnt too bad on the road  but was a bit heavy to chuck around in the forest, front wasnt bad just the heavy arse end and the fat tank
Doc
« Reply #16 on: April 05, 2008, 10:12:47 pm »
Pokey my shocks do seem a little cantered forward. I noticed this once before then didn't think about it again. So far as I knew it was all kinda stock but some pics show different :-\ maybe a TS400 swingarm??..it came with TS400 forks and alloy wheels so I guess it follows suit the swingarm could be from the same donor..good chance it's a little longer than stock if it is..will take a good look tomorrow morn.
« Reply #17 on: April 06, 2008, 07:32:21 pm »
i go past Jap dismantlers all the time what do you guys want off it or you want me to get the whole thing if its still there ? i can post it to you ?
Doc
« Reply #18 on: April 07, 2008, 03:26:23 pm »
that's very kind of you Freaky  :) me, myself and I speaking as one would like the pipe if a deal could be swung somehow, the rest including the mag cover is not essential as I'm going to build a TS/TM250K/J/L/M/A/B model anyway  ;D I have most bits except the pipe..I've a stock TS250 pipe for emergency back-up and even though it cuts the noise considerably 1 can assume it will sap performance even more ;D I'd like to get the whole thing but then I'd need to go out back and shoot myself cause I really don't need it! yet :P just the pipe would be cool but if not, no hassles, a downpipe would be far cooler 8)
« Last Edit: April 07, 2008, 04:07:00 pm by Doc »
« Reply #19 on: April 07, 2008, 05:03:17 pm »
ok so thats a no ? then.
Doc
« Reply #20 on: April 07, 2008, 05:12:18 pm »
yeah, thanks but no thanks Freaky, if it were in Bris. it would be a different story but it's too much trouble for too little for me ;)
« Reply #21 on: April 07, 2008, 07:02:03 pm »
Thought about it , nah got too many projects on the go  8) thanks all the same Freaky
« Reply #22 on: April 07, 2008, 09:56:57 pm »
ANy of these parts fit into the TM 250 ? like is it a 74 frame ?:?????
Doc
« Reply #23 on: April 08, 2008, 06:43:50 am »
basically a '74 TM250 frame with tabs/holes for lights, different footrests. Motors bolt straight in, triples bolt on, I think the rear loop is a little longer but yup..should pretty much be the same frame when it comes to engine fitting and geometry. The frame 'maybe but I don't think so' a little different on the right for the upswept exhaust but that goes behind the TM covers anyway. Also the rear brake pedal pivot is different. My TMS250 project will be utilizing a 73 TS frame for the simple reason I don't feel bad modifying it if I need or want to. Why don't you drop in and take a look at it for yourself..
« Last Edit: April 08, 2008, 08:44:20 am by Doc »
« Reply #24 on: April 08, 2008, 08:49:22 am »
did it say it was a 76 model ? im assuming they satyed the same as the 73 then from what you are saying.   JUst unless my 74 stuff fits straight in i dont need more junk.
Doc
« Reply #25 on: April 08, 2008, 08:58:59 am »
take a look Freaky..that's the easiest, I'm not going to over commit myself. I use this stuff all the time and mix and match and swap and change and I make things fit if they don't. I can't say for certain it would all bolt 'straight' up but I can say for certain I'm using 74 TM cases, 73 TS frame and whatever else will bolt on to get me rolling. The 76 TS frame would work for me..it's probably closer to 74 TM than my 73 frame is. Forks and clamps are a mm different but you'll probably find the TS clamps/forks are lighter anyways  ;)
« Last Edit: April 08, 2008, 09:00:31 am by Doc »
« Reply #26 on: April 08, 2008, 11:11:46 am »
freaky
         Front is pretty much the same . Different in the rear end department .....So hack away
« Reply #27 on: April 08, 2008, 03:19:07 pm »
the covers getting up to the $100 mark now, wonder if it will get over 100..???.
I just punched in bike australia on ebay and the first ADB Mag and no 2,no 4 and no 5 are up for sale.
« Last Edit: April 08, 2008, 04:03:40 pm by vmx247 »
Doc
« Reply #28 on: April 08, 2008, 07:21:41 pm »
makes the ebay bike seem all the more attractive for parts if nothing else. You could probably assume the mag cover on the TS has damage in some regards but the pics are not large enough to see with any clarity. If it is 76 it should have alloy wheels also with possibly no cracking. the clutch cover, mag cover are TM items. The pipe is obviously Bassani or something and with or without a rub back and coat of paint is worth $50+ every day of the week. For the $ it's good value but for me it's the location that's most important for parts bikes ;)
oldfart, you won't forget about those homeless honda's will you ;D I was given a vintage car yesterday  ::) well it's pre '85 anyway. A little green gemini..I've whacked it straight on egay for some cd-5 fuel and gourmet roadside diner funding  ;) wish I could have '84 model bikes given to me but one can't be overly picky..not a bad little car but alas..it's a car not a bike so it goes..ebay item 170209185088..Suit Kawasaki enthusiast :D Could be a nice thing if fitted with a big block!  ;)
« Last Edit: April 09, 2008, 05:51:09 pm by Doc »
« Reply #29 on: April 08, 2008, 07:59:17 pm »
PM sent
