Author Topic: Drysdale Dryvtech 2x2x2Experimental Hydraulic 2wd and 2 steer bike.  (Read 16004 times)
Offline pmcburney
Re: Drysdale Dryvtech 2x2x2Experimental Hydraulic 2wd and 2 steer bike.
« Reply #15 on: June 09, 2012, 09:43:59 am »
You know, you can get your own bike converted if you have the readies...
http://www.christini.com/awd-technology/about-the-technology
« Reply #16 on: June 09, 2012, 10:37:06 am »
Without trying to sound like an engineering wizard, I can't see it ever being a viable project.
Written in big letters all over it is "Experimental"
It was a test bed of ideas that he turned into a reality
Backwards cylinders are only now becoming common place
Mechanically it's impossible to provide the same amount of drive to the front wheel as the rear
I don’t think the intention is to get the same drive to the front as the rear. I believe the 2WD works best with a small amount of drive to the front so the front can help pull in certain conditions.
I think that’s what makes the hydraulic systems better than any mechanical drive system as the hydraulics can be controlled easier to provide different drive to each wheel.
I believe the Ohlin’s system has a sensor on the front and rear wheel’s that determines how much drive to give the front wheel depending on what the back wheel is doing.
Offline RED ALERT
« Reply #17 on: June 09, 2012, 03:36:44 pm »
Interesting, though it looks like it should have 'John Deere' stickers all over it  ;)
« Reply #18 on: June 09, 2012, 04:52:19 pm »
I agree with Geoff - easy to set a common hydraulic drive/pump setup to supply varying amounts of drive to either end through a proprotional valve or similar.  Could even make it adjustable if needed.
regards
« Reply #19 on: June 09, 2012, 09:13:54 pm »
The Ohlins system hasn't exactly set the world on fire..........................
