Author Topic: Who Knows?  (Read 8396 times)
Offline pancho
Who Knows?
« on: April 14, 2012, 03:52:23 pm »
 As I was pre-mixing some fuel for my RT1 this question occured to me--- What effect does adding oil to petrol have on the octane rating?
 Maybe the tech. teacher told me 50 plus years ago but I forget!
 Another who Knows question--- I know its possible to bronze weld and or braze with lpg  But is it feasable to fusion weld, sheet steel for instance?
 Cheers pancho.
Offline PCMAX
Re: Who Knows?
« Reply #1 on: April 14, 2012, 03:56:27 pm »
Not sure about effect on octane rating but there is some interesting reading in the 1978 Cycle magazine article (link below). Apparently the richer the mix the more HP up to a point.....
http://www.bridgestonemotorcycle.com/documents/oilpremix6.pdf
Offline pancho
Re: Who Knows?
« Reply #2 on: April 16, 2012, 08:30:17 pm »
 That is an interesting article, thanks PC
Re: Who Knows?
« Reply #3 on: April 17, 2012, 05:12:02 pm »
Would slightly increase octane ............maybe but oil has a higher calorific value than fuel
Re: Who Knows?
« Reply #4 on: April 17, 2012, 06:04:24 pm »
you cant fusion weld steel with lpg but good for cutting with the correct tip of course and blazing/silver solder.i remember Lozza saying the more oil the more power but theres a limit on that as well before plugs over oil and foul,rejetting is needed as well.
Offline micks
Re: Who Knows?
« Reply #5 on: April 17, 2012, 08:07:03 pm »
pancho you know how to fusion weld already.evertime the RT1 seizes ;)
Offline pancho
Re: Who Knows?
« Reply #6 on: April 17, 2012, 08:16:20 pm »
 No doubt about it micks you're right on the ball!
 Where were you anyhow, making another add?
    [Hi Barry!]
 Don't shave the beard off!
 Pancho
Re: Who Knows?
« Reply #7 on: April 17, 2012, 08:37:45 pm »
 Cheers pancho.
I pissed off the Acetylene bottle with its rent and high cost years ago.
LPG works great for cutting, brazing and heating.
I did hear that it wasn’t much chop for fusion welding but I scoffed at the rumours until I tried to do some fusion welding on a muffler to create those ‘old school’ look welds.
My results looked more like first time at school welds, just couldn’t get the flame right to get a decent ‘puddle’
I eventually gave up and just weaved with the TIG to get the look I wanted.
Setting the flame right with Acetylene is a piece of piece but LPG is a new trick this old dog can’t handle, and can’t be bothered learning for that once in a blue moon job.
Offline Mike52
  • 81 KTM 125 LC
Re: Who Knows?
« Reply #8 on: April 17, 2012, 09:06:57 pm »
Interesting article.
Especially the bit about the 30/1 test providing the dirtiest piston then on another page they say that the 30/1 test gave the cleanest spark plug. ???
Re: Who Knows?
« Reply #9 on: April 18, 2012, 12:47:18 am »
15:1 gave the cleanest piston but the dirtiest plug, 15:1 gave the most HP and lower under plug temps 30:1 gave the least HP and the highest under plug temps. Inversely proportional
Offline paco
Re: Who Knows?
« Reply #10 on: April 18, 2012, 05:52:01 am »
Just as logic always insisted: It amazes me that I read from time to time scientific reports that proclaim what to the rest of us ,is just common sence.p
what ! Who me ? Nah
Offline Mike52
  • 81 KTM 125 LC
Re: Who Knows?
« Reply #11 on: April 18, 2012, 08:08:59 am »
What would have happened if they hadn't changed the jetting ?
Re: Who Knows?
« Reply #12 on: April 18, 2012, 10:07:15 am »
Would have run too rich or to lean. The fuel flow was calibrated to keep the same vicosity and AFR with the oil ratio changes
Offline Mike52
  • 81 KTM 125 LC
Re: Who Knows?
« Reply #13 on: April 18, 2012, 11:19:43 am »
So if they had NOT changed the jetting and had only changed the fuel oil ratio then they would have got different results ?
Would the 30/1 mix [30 parts fuel to 1 part oil ] have  more fuel  going through the engine than 25/1 and the 25/1 more than the 15/1 ?
If so wouldn't the 30/1 mix engine [which had come jetted for 25/1] be running cooler because it was running richer and the 15/1 run hotter because it was running leaner ?
The moment you change the parameters [ jetting/tuning ] then aren't the results false because the test bed [engine] is continually changing and you have no fixed reference point ?
They said that the spark plug got hot on the 30/1 test but if they changed the jetting why did they not put in a different heat range plug  ???
Re: Who Knows?
« Reply #14 on: April 18, 2012, 01:59:35 pm »
No the fuel flow and viscosity were calibrated. So the same amount of fuel flowed out the jet(whatever size it was) with the different oil ratios. If the same amount of fuel flows out the jets then the AFR  remains constant. If you did not calibrate fuel flow for the different viscosity of the oil ratios then left the jetting unchanged you would be making the AFR richer and leaner.
. . . after a lot of fiddling with carburetor
jets. When you feed an engine 20:l premix,
only 95 per cent of the fluid passing
through the carburetor is fuel; five per
cent is oil, which does not burn. In switching
to a 30:l premix, we dropped the oil
content to 3.3 per cent and changed the
fluid's viscosity in the bargain, which
meant the engine's air/fuel ratio would be
changed unless corrective measures
were taken. We took those measures,
flowing premix through main-jets into the
dark of one night and almost to the
lunchbreak of the following day, until we
had achieved fuel-flow parity between the
20:l and 30:l gasoline/oil mixtures.
