Author Topic: CRM 250AR  (Read 15758 times)
Offline Tex
Re: CRM 250AR
« Reply #15 on: March 29, 2012, 09:33:30 am »
I believe there was an Activated Radical Special Edition as well...
There was a Mugen version - is that what you're talking about?
No, the CRM250ARSE.
Offline Canam370
Re: CRM 250AR
« Reply #16 on: March 29, 2012, 10:56:57 am »
No, the CRM250ARSE.
   ::) :D
But they did do an RS version.......CRM250ARRS
« Last Edit: March 29, 2012, 11:34:26 am by Canam370 »
Re: CRM 250AR
« Reply #17 on: April 08, 2012, 10:07:20 pm »
http://www.youtube.com/watch?v=_Rk76UxTk3g&feature=relmfu
Working on the jetting and recalcitrant servo for the PV, should go OK once dialed in  ;)
Offline Marc.com
Re: CRM 250AR
« Reply #18 on: April 09, 2012, 08:46:17 am »
Sounds like it lifts its skirts once the power valve is open. Are you using CRM or CR one ?
Just picked up another CRMAR motor with new bore for $300, couldn't help myself. Plus a set of Chinese CR250 radiators.
Re: CRM 250AR
« Reply #19 on: April 09, 2012, 09:41:45 am »
CR cylinder, the servo isn't connected ATM swapping to a yamaha servo sound be sweet then.
Offline Marc.com
Re: CRM 250AR
« Reply #20 on: April 09, 2012, 09:50:11 am »
Yeah this one just came home because I needed a kickstart  ;D .... plus only 2 weeks shopping before I leave Tokyo with my 1.7 tonnes of bike parts under one arm  ;D.
I am using all the original CRM gear plus the oil pump which requires a tricky 3 cable throttle .... looking for least amount of hassle and fairly flat power characteristics and bottom end that CRM AR were known for.
Re: CRM 250AR
« Reply #21 on: April 09, 2012, 02:58:46 pm »
They only have bottom end and no real HP to speak of  ;D
Offline Marc.com
Re: CRM 250AR
« Reply #22 on: April 10, 2012, 05:01:50 pm »
What pipe are you using Lossa, I have CRM double walled one that is heavier than the engine. :o, no worries about denting it though.
Offline oldyzman
  • 250 two stroke!
Re: CRM 250AR
« Reply #23 on: April 10, 2012, 09:35:43 pm »
I put a pro circuit pipe on mine when i had it, the old pipe was heavy...
Re: CRM 250AR
« Reply #24 on: April 11, 2012, 11:10:39 am »
You'll be rich from the recycle value. Standard CR250 is the go.
Offline Marc.com
Re: CRM 250AR
« Reply #25 on: April 11, 2012, 12:20:29 pm »
Just picked up NOS CR 250 standard pipe and managed to save myself a chunk of change from what the thieving dealers wanted for FMF.
Re: CRM 250AR
« Reply #26 on: April 11, 2012, 01:48:37 pm »
Got a heap of free HP too.............. ;)
