Author Topic: Shed Clean Out - Listing here before Evilbay  (Read 2187 times)
Simo63
« on: March 18, 2012, 11:22:18 pm »
Thought I'd give you guys and gals a chance at some of my junk .. errr treasures before I banish them to ebay.
  • TS400 Centreport Cylinder. I think this is a TS Barrel, it's suzuki and it's 398cc so it's got to be close. Includes piston and rings but no guarantees on those items as they are chucked in for free. $75
  • YZ250 1986 Cylinder and Head, Good condition, surface rust, not certain what bore diameter is but could check if anyone's interested, No sign of big end letting go etc. $75
  • YZ250 1986 Inlet manifold and modified Reed Block. Good Condition, $30
  • PW80 Kick Starter, Excellent condition, $30
  • PW80 Clutch Assembly. Condition Unknown, $10
  • PW80 Magneto, Good Condition, no damage $25
  • TS/TF 125 Gear Selector Shaft.  I though this was NOS it's that good but I can see the smallest sign that it has been used but it mustn't have been for long $40
  • 1986 CR125 RG crank shaft.  Seems to be in good condition and could be used however I would never use a 2nd hand crank when new ones are so cheap but this might suit someone for a rebuilder $40
  • 1984 CR250RE Clutch cover including water pump impeller and cover $200. Minor corrosion has been fixed and water pump works very well.  Good ones of these are rare  - ON HOLD
  • 1984 CR250RE Front wheel including disk and good tyre (no bearings) $125
  • 1984 CR250RE Front forks, dismantled, excellent chrome, missing bottom bolts that screw into the damper rods and hold it all together $150
  • 1984 CR250RE Genuine front brake master cylinder, brake line, brake lever and good brake calliper, complete spare set with brake fluid in and ready to bolt on $100
  • 1984 CR250RE Genuine alloy rear brake lever, $50
  • 1984 CR250RE Genuine Honda clutch cable, very good condition, $20
  • 1984 CR250RE Genuine ignition system, complete from flywheel, rotor, all wires, coil etc.  Again complete bolt on unit (however alloy backing plate is cracked) and a hard to get set.  $350
  • 1984 CR250RE Genuine complete throttle setup including cable, ready to bolt on and ride $75
  • 1984 CR250RE Genuine rear shocker stone deflector, cracked but still usable with a little work, ultra hard to find $15
  • 1984 CR250RE Spare alloy clutch plate spacers, good condition, set of 6 or 7 (can’t remember) $20
  • 1984 CR250RE New aftermarket front brake lever, still in packet, $12
  • 1984 CR250RE Brand new aftermarket rear brake shoes $20
  • 1984 CR250RE 51T rear sprocket, used $10
  • 1984 CR250RE 40T rear sprocket, used $15
« Last Edit: March 19, 2012, 08:45:02 am by Simo63 »
Offline Kenneth S (222)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
Re: Shed Clean Out - Listing here before Evilbay
« Reply #1 on: March 20, 2012, 07:10:41 am »
Hi Simo,
Not sure whether you received my PM I sent early yesterday morning but I am interested in the following:
Kenneth S
Go For It
Race Bike History
Simo63
« Reply #2 on: March 20, 2012, 11:05:17 am »
Hi Kenneth
Yes got your email and will hold those items except the watercover that was already on hold as someone beat you to it (I just hadn't made that change to the listing).  If that sale doesn't go through it's definately yours as well as the other stuff.
Craig
Offline crs-and-rms
  • heaven 23
« Reply #3 on: March 22, 2012, 08:12:05 pm »
im keen on the forks if they are not sold
Simo63
« Reply #4 on: March 23, 2012, 01:37:23 pm »
Not sold so send me a PM or email and we can go from there.
Craig
