Author Topic: 35mm Betor forks  (Read 2278 times)
Offline bazza
35mm Betor forks
« on: February 19, 2012, 11:26:56 am »
have done the Sudman suggestions on my forks-on BSA b44.with xtra 20wt oil.  Any one run stronger springs or PD valves or both? Back end of bike works well front not right yet.
Embrace patina
Offline sudman
Re: 35mm Betor forks
« Reply #1 on: February 19, 2012, 12:22:09 pm »
Go to 30wt Bazza makes a big differents it was like night and day on my bike. Gavin gave it the big thumbs at the naki track for the way they worked.
Offline huskibul
« Reply #2 on: February 19, 2012, 12:58:27 pm »
   Bit of a highjack,but a couple of years ago i came across a site where a bloke in us or canada modified 35mm betors for race bikes using cartridges or something similar that ! does anyone know of the bloke/mods ?  cheers
Offline bazza
« Reply #3 on: February 19, 2012, 02:14:22 pm »
thanks Walter and thanks Sudman will try the 30weight for next weekends classic scramble club meeting
Embrace patina
Offline asasin
« Reply #4 on: February 19, 2012, 03:17:27 pm »
I Have the 290 valves and original progressive wound fork spring weight in my cooper/ yamaha they work ok with 1o weight but i did not drill the holes same as per the pd sheet i took a punjt and copied the drill hole layout in a VMX a few issues ago that showed a works CZ fork tube and a standard one  .seem to work well ,very progressive and do not bottom out , i am over 100kg geared up
« Last Edit: February 19, 2012, 03:25:29 pm by asasin »
If in doubt ,WIND IT OUT
