Author Topic: Simons for pre 78?  (Read 90807 times)
Offline HVA61
Re: Simons for pre 78?
« Reply #30 on: February 14, 2012, 11:01:12 am »
Well there you go then ,learned something new today . Snowy post a pic of the Simons you have.
Offline 09.0
« Reply #31 on: February 14, 2012, 11:03:58 am »
The answer to the question is yes, they are legal to run. I have a set on my rm125b and are restricted to 9". The Simons are all the same except for the length of the dampening rod which determines the travel (how far it extends). The staunchings are all the same length. Fox forks were not available in '77 so naturally not legal.
And what Tm Bill said. Even those husky forks may be legal if the travel has been restricted.
Offline motomaniac
« Reply #32 on: February 14, 2012, 11:09:32 am »
nice bike anyway
Offline HVA61
« Reply #33 on: February 14, 2012, 11:12:15 am »
Thanks , i like it
Offline motomaniac
« Reply #34 on: February 14, 2012, 11:13:24 am »
If Simons are all the same why does the MOMs copied from the US AHRMA specifically state "early model Simons" that are restricted to 9" travel ? and not just Simons that are restricted to 9" travel?
Offline HVA61
« Reply #35 on: February 14, 2012, 11:17:36 am »
Maybe they are referring to early simons forks as pre USD Simons forks.
« Last Edit: February 14, 2012, 11:28:30 am by HVA61 »
TM BILL
« Reply #36 on: February 14, 2012, 11:36:12 am »
Makes sense  :) and those rules were written in A Maori car, home of the brave land of the lawsuit  ;D They would need to be word perfect and cover all bases  ::)
A Maori carn rules are probably not the best template for countries like Australia or NZ where common sense is used rather than call 0900 sue my arse off when things go pear shaped  :)
« Last Edit: February 14, 2012, 12:34:16 pm by TM bill »
« Reply #37 on: February 14, 2012, 11:37:38 am »
I'm pretty sure all the Simons forks are the same other than the amount of travel. I've got a set of 11" travel Simons that are still 38mm, maybe the stanchions are longer but I could still restrict them to 9" travel and use them.
« Reply #38 on: February 14, 2012, 11:45:14 am »
Emulators and modern shocks are legal in all eras as they are internal and not visible. Fork and shock internals are free the same as eng.
I haven't found that clause in MOMS yet , still reading. ::)
I was under the impression emulators were not legal in pre 78 because it's a performance enhancing mod that was not available in the day...
Offline motomaniac
« Reply #39 on: February 14, 2012, 11:46:18 am »
lucien
« Reply #40 on: February 14, 2012, 11:55:21 am »
IS my 79 SWM ok for pre 78 if i put 77 forks in ,so  if it look likes the 77 model?
Offline huskibul
« Reply #41 on: February 14, 2012, 12:19:47 pm »
   Why wouldn't you can all the bull and blanket fix the lot ! pre 75' = 7"&4" or 8"&5" with 35/36mm tubes   ,pre78' = 9"&9" or 10"&10"with 38mm tubes -factory/aftermarket or restricted  !  :-\
Offline Snowy 76
« Reply #42 on: February 14, 2012, 12:27:24 pm »
Thanks for the Reply`s and info,so looks like it`s all go  ;D ;D ;D  time to hurry up the powder coater . Thanks Birko.
Couple of CR`s
Offline 09.0
« Reply #43 on: February 14, 2012, 01:33:04 pm »
length of the dampening rod is the only difference. I had three sets apart at once to compare.
« Reply #44 on: February 14, 2012, 02:48:30 pm »
Interesting... did you shorten the rods or put spacers on them to lessen the travel?
