Author Topic: 360 explosion...  (Read 3345 times)
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
360 explosion...
« on: January 04, 2012, 06:30:18 pm »
This is what happens when a piston lets loose at high rpm :'(
Re: 360 explosion...
« Reply #1 on: January 04, 2012, 06:56:27 pm »
  Is the barrel ok as it looks like the rod is slightly bent also.
   Was it over due for a piston and  has dropped the skirt resulting in this ???
Offline Canam370
« Reply #2 on: January 04, 2012, 07:02:30 pm »
ooooohh - that's not meant to look like that  :o
 I had a chunk of piston skirt try to get out the inlet port of my 125 Canam once. Trouble with that was it didn't get out quick enough and the rotary disc caught it halfway out. 9000rpm to 'oh shit' in a nanosecond! Didn't look quite as dramatic as the Mont but it took ages to untwirl the peeled disc out of the cases. Sorry for the hijack :-*
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #3 on: January 04, 2012, 07:43:23 pm »
The cylinder liner was broken as well. The engine cases are ok. Piston clearance was at
.0035" when checked a couple of months prior to the explosion. (installed new rings)
It was a Mahle piston.
Offline holeshot buddy
  • sunshine coast qld
« Reply #4 on: January 04, 2012, 07:51:43 pm »
shite jared it has let go big time
i had a kx500 do this it was a standard cast piston
same result sleeve gone rod bent alloy everywhere
follow me to first turn
