Author Topic: RM125N  (Read 10396 times)
Re: RM125N
« Reply #15 on: January 12, 2012, 10:48:53 pm »
I had a 125N back in the day and don't remember it being much different to the T other than the guards and swingarm chain guide.
Re: RM125N
« Reply #16 on: January 12, 2012, 11:21:23 pm »
I thought the n/t were basically the same too
crankpin
Re: RM125N
« Reply #17 on: January 13, 2012, 07:17:35 am »
Thanks for the info.
Looks like I'm after a Full PE175 engine then  ???
Re: RM125N
« Reply #18 on: January 13, 2012, 07:44:52 am »
Yep, i've got a pe175x I use in mx. Really nice motor
Offline YZ250H
  • Back in QLD Baby !
Re: RM125N
« Reply #19 on: January 13, 2012, 08:04:55 am »
Yep, Mainlines PE is too much bike for Hoony and Roger HArvey  :o :o :o ;D
Re: RM125N
« Reply #20 on: January 13, 2012, 10:37:28 am »
I knew the pe was too powerful for Hoony, didn't know that Rog was scared off as well?
Offline YZ250H
Re: RM125N
« Reply #21 on: January 13, 2012, 11:24:06 am »
He was too scared to take it out I think  ::) ::)  You were out getting mud on some other poor blokes bike  ;D
monaro308
Re: RM125N
« Reply #22 on: January 13, 2012, 03:44:51 pm »
Here is some homework i've done for you although its an RM100X frame,its basically the same frame as the N,T 125s
With the RM100X cases in the frame.....its natural home
Now with the PE175C engine,similar engine design to your 125N but the cases are wider by approx 5mm
so your frame case  mounts need to be widened.
Same 175C engine in the frame
Now we move onto the later PE175Z-E floater motors which is again 5mm wider to your 125N motor
Same 175Z-E motor in frame BUT is also wider at the sprocket side (further out) by about 8mm to the other engines.
These also had an extra case mount hole at the bottom.
I'm not 100% sure if the PE175T-X engines were the same design as the Floater engines (Leith and Luke would know)
even though i owned an X for 9 years,but i'm leaning towards a yes.
To add to that as well was that these engines had a bracket that is held/mounted between the swingarm
As the others also said,cylinder/reed spacings are all different as well.
All said and done,it will still be that engine mount brackets and chain alignment plus the fiddly time consuming
pipe,muffler stuff to do.
Re: RM125N
« Reply #23 on: January 13, 2012, 04:23:05 pm »
I  will post up some pics latter on of the difference in cases from N to T with Pe 175 motor......Need a Cuppa and a nanny nap first  ;)
Offline vmx42
Re: RM125N
« Reply #24 on: January 13, 2012, 04:54:46 pm »
125T with PE175. 1984 RM125 rear wheel and complete 43mm, twin leading shoe, front end.
Re: RM125N
« Reply #25 on: January 13, 2012, 05:09:03 pm »
Ok I'm back  you will notice the cases have had a complete redesign from 79 to 80 on Rm 125
left to right are  Rm 125   1979  -  Rm  125 1980   and  a Pe 175 1981
« Last Edit: January 13, 2012, 05:42:59 pm by oldfart »
crankpin
Re: RM125N
« Reply #26 on: January 13, 2012, 06:48:25 pm »
Wow, great info. Thanks.
oldfart, have you any closer images or info on the frame mods at the rear engine mounts?
Thanks again.
Simon.
crankpin
Re: RM125N
« Reply #27 on: January 13, 2012, 07:03:57 pm »
Very neat.
Any specifics on the mods?
crankpin
Re: RM125N
« Reply #28 on: January 13, 2012, 07:08:53 pm »
Any closeups?
Cheers.
Re: RM125N
« Reply #29 on: January 13, 2012, 08:34:53 pm »
Simon, larger pics sent.
