Author Topic: Timing YZ400E  (Read 7502 times)
Offline yzhilly
  • Melbourne
Timing YZ400E
« on: August 10, 2007, 02:44:32 pm »
Can someone help me out with the timing checking procedure for YZ400E, I have the spec 2.7mm BTDC. I have a multimeter and dial indicator but i dont have manual on it please help.
Viper #436
Re: Timing YZ400E
« Reply #1 on: August 10, 2007, 07:23:14 pm »
Does the engine have the internal rotor/ external stator? If yes should have 3 lines on the stator, the mark on the rotor should line up with the longest line on the stator at 2.7mm BTDC.I have done this many a time on a YZ 80 ignition always works out right.The internal stator/external flywheel type usualy has 2 marks on the flywheel at TDC the second mark usualy is smack bang underneath the trigger.
HTH
Offline yzhilly
  • Melbourne
Re: Timing YZ400E
« Reply #2 on: August 10, 2007, 10:06:27 pm »
Thanks Lozza it's external flywheel, I will check it in the morning .It's getting closer to how it should go its still running rich but i will try adjusting the needle clip tomorrow
Viper #436
Offline YZ250H
  • Back in QLD Baby !
Re: Timing YZ400E
« Reply #3 on: August 12, 2007, 05:41:56 pm »
As per 400E post I will scan some pages of the manual and email to you.
Cheers ;)
Offline YZ250H
Re: Timing YZ400E
« Reply #4 on: August 13, 2007, 08:58:45 am »
Check your emails Hilly - there should be a few scanned pages in there  ;)
Offline yzhilly
  • Melbourne
Re: Timing YZ400E
« Reply #5 on: August 13, 2007, 10:09:37 am »
Got it thanks Tony.
Viper #436
