Author Topic: Rickman Zundapp Metisse Build  (Read 43882 times)
Offline Tossa
Re: Rickman Zundapp Metisse Build
« Reply #15 on: December 15, 2011, 11:38:11 am »
Yeah mark i know about him, have been in contact with him and will be picking his brain
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
« Reply #16 on: December 16, 2011, 10:00:53 am »
flower Pot Bens Mk3 glass on my Rickman Zundapp with the Maico wedged in there.
Offline Tossa
« Reply #17 on: December 16, 2011, 11:17:42 am »
looking good mark, this appears to be a time of metisse.  Will be an interesting year
« Reply #18 on: December 16, 2011, 11:59:22 am »
Yeah Tossa, by rights I should have had mine finished but I keep getting distracted by other project bikes.
As soon as I've finished the flat track project and sorted the Hindall DT1 and Cheney for the Nats I'll get back into the Metisse with its new Cooper powerplant.
Offline Tossa
« Reply #19 on: December 16, 2011, 12:50:59 pm »
motor will be on the way soon also found a tank for VMX60's CZ, so things looking up.  Will email Terry Team Zundapp USA davis about the selector, see where we end up.  Will be really interested to see where you go with the Cooper
« Reply #20 on: December 16, 2011, 02:34:14 pm »
Left field for a start!  ;)
I've just been out in the shed fiddling around with stuff and plonked the motor into the frame to see what's needed once I get to it. Not only is the Moto Islo a sweet fit, the Zundapp upper rear mounts almost line up with the Moto Islo crank case mounts 8). They'll have to be redrilled but that's better than having to reweld new mounts....damaging the perfect nickel. Some things are mean't to be ;D
While I was rooting around I tried my T100 Trumpy motor and sure enough, it fitted in there as well! It's a really tight fit and to be frank it'd be a bitch to work on but it can be done. I fitted a T100 motor to a Bultaco M11 (Metisse copy) a few years ago and it was a similar tight fit. While I was sitting having a cup of Java looking at the Triumph in the little Rickman it dawned on me that a CB350 twin would be a beut swap into the frame....it'd be sort of a scaled down Triumph Metisse. I've got a CB77 305 engine in the glory hole, If it wasn't tucked away so securely I'd dig it out to give it a try...... ::)
« Reply #21 on: December 16, 2011, 02:39:32 pm »
so you wont need that t100 it will fit right in the ariel duplex frame
« Reply #22 on: December 16, 2011, 02:51:38 pm »
You can go stand in the naughty corner too Jim.
Offline Tossa
« Reply #23 on: December 16, 2011, 03:12:31 pm »
Can i ask the rear shocks your using on the Maico  I'll be looking for some
« Reply #24 on: December 16, 2011, 04:01:12 pm »
I haven't got that far yet, but it'll probable be a pair of my 13.5" Arnaco's or alloy Konis. This being a low budget build, I won't be spending on exotic stuff.
Offline Tossa
« Reply #25 on: December 20, 2011, 11:34:39 am »
I am going to have a great Xmas a zundapp motor (that turns over, a seat base) and a Tank for murray are on the way
Offline VMX60
« Reply #26 on: December 20, 2011, 12:09:41 pm »
Tank you Santa  ;D
Offline Tossa
« Reply #27 on: December 20, 2011, 12:12:19 pm »
Ho Ho Ho  :D
Offline Tossa
« Reply #28 on: December 24, 2011, 12:41:27 pm »
Santa came early and the motor has arrived, just needs unpacking.  Thank you to all concerned
Offline Tossa
« Reply #29 on: December 24, 2011, 02:07:19 pm »
things getting even better just been offered a new set of arnaco shocks, what a great Xmas, thanks Geoff
