Author Topic: REMOVING OLD CONTACT FROM FIBREGLASS TANK  (Read 7378 times)
« on: November 24, 2011, 04:01:03 pm »
I have a Frontera tank that I'm struggling to get some old contact off. It's brittle and hard as a cats head. I've had a little bit of luck laying a rag soaked with turps on the surface but its still hard work. I have now officially run out of fingernails and hope that someone out there can offer some advice. Thanks Jerry
Re: REMOVING OLD CONTACT FROM FIBREGLASS TANK
« Reply #1 on: November 24, 2011, 04:22:53 pm »
Heat gun  ;) 8).
Offline chrisdespo
« Reply #2 on: December 27, 2011, 08:36:06 am »
Hey jerry we have a bit of luck with a product called Citraforce, they have just changed the formula in bulk but you may still be able to get a sprsy can of the old formula if anything will work it would be that stuff it will dsolve dry tar off the cabs of our trucks lust spray on leave and watch it run off then hose off dosn't seem to harm the paint work.... as always the new formula is a step backwards but oh well still works something to do with the cost of citrus.
When in DOUBT GAS IT!!!
« Reply #3 on: December 27, 2011, 10:59:13 am »
G'day Jerry, i have found that CRC / WD40 takes off the gluey adhesive residue left after removal of things (like stickers), not sure if it will attack the old contact though. try it on a test patch.
have you tried a range of solvents (Metho, acetone etc) ?
like Chrisdespo mentioned, try the citric acid products (Orange Power brand "sticky spot and goo dissolver" from supermarkets is a good one) maybe try eucalyptus oil.
« Reply #5 on: December 27, 2011, 12:17:39 pm »
I've used Orange Power and another citric acid based product with great success. To remove stickers I use a hair dryer or a heat gun on low to warm and soften the sticker and glue. They come off in little time and the glue residue will quickly come off with a rag soaked in the citric stuff or even thinners or turps although thinners may remove some paint. Try Orange Power first.
Offline dalesween
« Reply #6 on: December 27, 2011, 01:26:35 pm »
Fingernail polish remover works well for the gooey stuff left behind.
cheers Dale.
« Reply #7 on: December 28, 2011, 12:37:55 pm »
Thanks guys. Let you know how I go. By the way Happy New Year to you all. Cheers Jerry
« Reply #8 on: December 28, 2011, 05:02:27 pm »
RP7 -WD40 any fish oil based product like that will soften it like butter
Offline lyle2212
« Reply #9 on: December 29, 2011, 09:23:54 pm »
I,ve done 2 frontera tanks .they are fibreglass so just get out the bloody electric sander and go to town on it. Then get yourself some car bog and give it a touch up. I have just finished the Gold Medal tank and the gold colour I bought in a pressure pack from CHEAP AUTO PARTS.  The colour is called CONTESSA GOLD. It,s a discontinued stock but get them to check on the computer for other stores that may still have it in stock, and you might get lucky like I did.  And don,t forget to get a can of clear finish.              Also I cross threaded the petcock thread on the tank today and I was friggen spewin,so I went down to the bolt shop and for $32 they gave me a complete self tapping and rethread kit complete with thread inserts. Drill it out, tap the Oversize thread, then screw in the thread insert back to standard size" Bloody Unreal".   Threw the tank back on and went for a ride around town and I just got back.
REGARDS ..LYLE
Uploaded with ImageShack.us
« Last Edit: December 29, 2011, 09:26:25 pm by lyle2212 »
Offline bazza
« Reply #10 on: December 30, 2011, 09:17:11 am »
nice job.Hope car bog does not "pop" out with leaching from petrol fumes. Been there done that,then got trick boat epoxy 16yrs later perfect.
Embrace patina
« Reply #11 on: December 30, 2011, 09:30:24 am »
Thanks guys Acetone did the trick. Gotta say not bad mixed with Coke either. Lyle if you know anyone with a spare toolbox to go on the Frontera tank let me know. Rare as chook teeth! Cheers Jerry
Offline lyle2212
« Reply #12 on: December 30, 2011, 02:25:50 pm »
There is a Tank Tool Box on Ebay now. Also Peter Shoene sells them.  Another important thing I forgot to mention when refurbishing old fibreglass tanks is that you must do the inside of the tank as well by resealing it with epoxy . This might sound like a big job but it is actually quite easy. You just buy the 2 pack mix and pour it into the tank then just keep turning the tank over and over for a complete seal. This will ensure no fuel leaks as these old tanks get brittle inside and out, again Peter Shoene is the man to contact, regards lyle.
« Last Edit: December 30, 2011, 02:32:08 pm by lyle2212 »
Offline lyle2212
« Reply #13 on: December 30, 2011, 03:27:27 pm »
Jerry here,s a couple of photos that you requested,
The GM is registered and is my daily ride, the MK11 is a 370cc and is my current project.
« Reply #14 on: December 30, 2011, 06:59:34 pm »
VERY NICE LYLE! Must turn a few heads at the lights! J
