Author Topic: Anyone got a bigger hammer?  (Read 10153 times)
« on: March 09, 2008, 06:28:19 pm »
I have a problem getting a barell off. The piston seems to be seized into place through years of being in the elements without a sparkplug in place.
The crank still spins( I took the base nuts off and I can lift the barell), but the piston seems wedged in there.
I have tried all the standard soakings and heat to the cylinder and bashing, so far no good.
Any ideas?
Re: Anyone got a bigger hammer?
« Reply #1 on: March 09, 2008, 06:57:42 pm »
Block up all the ports with rags or similar and fill up the bore with brake fluid and let it soak it for a few days .
« Reply #2 on: March 09, 2008, 07:03:47 pm »
another option is to cut the rod in half with a cutting disc so you can get it on a press and press the piston out maybe.
assuming the crank will need a rod kit anyway due to the weather damage.
Offline paul
« Reply #3 on: March 09, 2008, 07:09:41 pm »
turn  it up side down in the vise and melt the piston with the oxy  a  bit
« Reply #4 on: March 09, 2008, 07:47:44 pm »
Brake fluid has gone in.
Hoony good idea but the piston is at about 15mm from TDC so I can't even get the cylinder off the bolts, if it was at BDC all would be good.
Paul, If brake fluid fails out comes the oxy.
Offline jimson
  • Sanctuary point N.S.W
« Reply #5 on: March 09, 2008, 11:26:11 pm »
Years ago I had the same problem undo the bolts on the barrel take the bike to the top of the biggest hill you can find lift the ass end of the bike and run like crazy then drop the back end down to the ground  you might have to do this once or twice but it should work its the sudden jolt that opens it up just be carefull you don't trip over the bike when you drop it also have a camera ready ::)  just in case.jimson
Offline holeshot buddy
  • sunshine coast qld
« Reply #6 on: March 10, 2008, 08:47:43 pm »
i got a kx500 engine off a guy his ex attacked it with an axe and poured sand and sea water
down plug hole  :o
was seized near tdc i soaked it in diesel for a week then got a big ::) hammer
suspended motor off ground and layed into it from the top >:(
like there was no tommorow
it worked took a bit though i only wanted it off to acces gearbox which was still ok ;D
follow me to first turn
All Things 414
« Reply #7 on: March 10, 2008, 08:58:14 pm »
Apparantly Hoony's technique is straight out of the Honda manual.....
Offline brent j
« Reply #8 on: March 10, 2008, 10:34:27 pm »
I made up a rig years ago to remove some cylinder from and old aircraft engine.
A plate bolted to the head studs with a threaded hole to accept a porta-power ram. We would build up some pressure, soak it in CRC or such and leave it over night. We used heat on a few but they all came off in the end. We were after the sleeves but usually did no or minimal damage to the other parts.
You could make something simillar by making a frame to bolt to the head studs and hold a car jack. Constant force on the piston with a bit of heat might get it to move.
Brent
« Reply #9 on: March 10, 2008, 10:50:07 pm »
I would try drilling some holes down through the top of the piston which should help relieve the pressure against the cylinder wall. The gudgeon pin will stop you breaking the crown off completely but if you get some large holes front & back you could then run a hacksaw blade through the skirt to also help relieve pressure, then try that big hammer again ;D
Use some good old duct tape to make a handle on the end of the hacksaw blade.
« Reply #10 on: March 10, 2008, 11:16:11 pm »
Don't try using 1200gms of Semtex plastic expl... it does not work...... And wastes a good detonator and KX80 gearbox,clutch ,head. barrel,frame, triple trees etc:(
« Reply #11 on: March 11, 2008, 05:23:45 pm »
Nice one   :D
Shit, i have no comeback ??? i'm losing it
« Reply #12 on: March 11, 2008, 05:26:03 pm »
Shit Tim, you really are Crazy (Glad i never swung for you  :D)
« Reply #13 on: March 12, 2008, 07:34:28 pm »
Oops Sorry Hoony incorrect fact stated, it was C4 not Semtex. Mate and partner in the "failed attempt to remove stuck barrel" has admonished me for that silly mistake. :-* And if i ever get the any of the 754s back on track, you can find a fool to hang on side and pilot them yourself on me no kidding  ;) Tim
Offline Wombat
  • Gold Coast hinterland
« Reply #14 on: March 12, 2008, 09:41:07 pm »
down plug hole  :o
Are you serious; she attacked it with an axe?! :o
Note to self: If bike becomes the Mistress, hide the axe...
"Whadaya mean it's too loud?! It's a f*ckin' race bike!! That pipe makes it go louder - and look faster!!"
