Author Topic: back support  (Read 3997 times)
Offline Marc.com
back support
« on: November 19, 2011, 12:11:24 am »
Just considering dropping some money into back protector / kidney belt / bondage gear, like a lot of us my back needs all the help it can get...... anyone have a recommendation
Re: back support
« Reply #1 on: November 19, 2011, 05:49:43 pm »
swear by the 661 body suit - looks after my back, kidneys and the fish net tight suit makes me look good also  ;D
Offline brent j
Re: back support
« Reply #2 on: November 19, 2011, 07:06:54 pm »
I've got a Dainese pressure suit.
It's very comfortable with no seams or pressure points. I wear it with a compression Tee shirt top, ie skins, 2XU etc.
I've had one big get-off on a rocky track and the gear proved it's worth. The scars on the armour (and boots, knee guards, gloves, helmet) proved it's effectiveness.
The compression top is supposed to help with breathing and recovery but what it does do is help to keep me cool. I wear the pressure suit over the 2XU top with nothing else. This keeps me comfortable in 30+ degrees and humidity over 90% even when we are in stop-start type riding while setting tracks etc
Offline Marc.com
Re: back support
« Reply #3 on: November 20, 2011, 11:06:12 am »
sounds good my lower back needs all the help it can get...... so would like the best support I can get short of a zimmer frame
Offline suzuki27
Re: back support
« Reply #4 on: November 21, 2011, 06:01:55 pm »
Hi Marc, do you wear a neck brace?
I've had a dianese for about 15 yrs and only had one zip replaced. Get a suit/armour where the back protector and kidney belt zip off the rest of the armour. That way you can mix and match with the neck brace and the rest of your ensemble. Check with Suzuki43 about matching fishnet tights; he'll point you in the right direction.
Offline Marc.com
Re: back support
« Reply #5 on: November 21, 2011, 06:58:08 pm »
Yeah Suzuki43 is the man to ask on that score, he has grown his hair a little longer lately.... you can hardly recognise him  ;D
Offline suzuki27
Re: back support
« Reply #6 on: November 21, 2011, 08:43:30 pm »
I can't put my finger on the exact reason why that piccy is so wrong. It's just wrong.
Did you get it off 43?
Taka 100
Re: back support
« Reply #7 on: November 21, 2011, 09:04:48 pm »
i dont beleive it i think met shim at the taxi club in 1987, hic#
Re: back support
« Reply #8 on: November 22, 2011, 01:39:10 pm »
until I saw that photo I was going to say " I miss Craig!!!!" but now.......................................
Re: back support
« Reply #9 on: November 23, 2011, 03:20:16 pm »
"Please ... check my balls"
number 87
Re: back support
« Reply #10 on: November 25, 2011, 10:34:22 am »
When threads go pear shaped . . . . .
MARCFX's ORIGINAL POST
FREAKSHOW's LAST RESPONSE
