Author Topic: MX vs DT cylinders  (Read 10747 times)
Re: MX vs DT cylinders
« Reply #15 on: November 07, 2011, 11:40:09 pm »
34mm is the standard MXA carby so why would you run anything else ?
30mm was standard ;).
Like i said MXA where 34mm
« Reply #16 on: November 07, 2011, 11:52:22 pm »
................ mine again is fitted with points, but some others claim they come standard with elec ignition.
I'm with Nathan on this - I'm 99.9% certain they all came standard with internal rotor CDI.
I swapped to the flywheel maggy for endruo - a great mod - pulled like a four stroke and revved like a two stroke 8).
« Reply #17 on: November 08, 2011, 07:29:21 am »
Me too.
Dunno about the 34mm carby though ::).
« Reply #18 on: November 08, 2011, 12:53:26 pm »
Your DT still going Nathan?
« Reply #19 on: November 08, 2011, 01:59:37 pm »
Which one?
The DT- powered MX250 copped the mother of all over-revs at Canowindra (not me!) and now has a multi-part piston - and rings through the main bearings.
The DT125 needs a rod after it swallowed dirt about four years ago... I've got the new crank ready to go in, but haven't found the time and motivation together in four years....
