Author Topic: Betor triple clamps.  (Read 2097 times)
Curly3
« on: November 05, 2011, 10:14:02 pm »
Is the headstock shaft screwed into or a shrink fit into the bottom triple clamp?
I need an extra 3mm to allow full thread on the top lock nut.
We all need a bit of extra length occasionally. :P
Offline matcho mick
    • Moto Tumbi
Re: Betor triple clamps.
« Reply #1 on: November 05, 2011, 10:33:14 pm »
think it has a step to stop it pulling through,i'll go & check,back in a tad ;D, :P
Offline matcho mick
    • Moto Tumbi
« Reply #2 on: November 05, 2011, 10:43:46 pm »
has a circlip approx 3mm in,i'd say press fit,looks like the later bottoms also clamped as per top triple, :P
Curly3
« Reply #3 on: November 05, 2011, 11:03:20 pm »
Good to See you home safe Mick, lucky bastard.
My clamps are 35mm and don't appear to involve a circlip.
Offline matcho mick
    • Moto Tumbi
« Reply #4 on: November 05, 2011, 11:31:54 pm »
yep,justa nother lucky bastard ;D,push the stem down through the bottom triple,that will expose the circlip slidey,probably a good idea to convert the bottom to clamping same as top tree arrangement, :P
« Reply #5 on: November 10, 2011, 03:13:44 pm »
Are you making the stem longer ? if so keep us posted, i got some betors triples i wanted to put in a Champion frame but there too short, or it needs a longer stem.... but thats as far as i got with it.
Happy to steal your ideas when you have it sorted out.
« Last Edit: November 10, 2011, 03:17:34 pm by Freakshow »
