Author Topic: 1974 tm250  (Read 8467 times)
Re: 1974 tm250
« Reply #15 on: November 01, 2011, 02:44:52 pm »
Guy's you are looking at a piece of history here .....  seriously this could be a pre mock up of a Rm A
Dave was this the one that had the RH motor in ????
albrid-3
Re: 1974 tm250
« Reply #16 on: November 01, 2011, 02:49:22 pm »
No, it had a Tm 250 engine in it. I think you are right in saying that they tried to mock up an RM.
Re: 1974 tm250
« Reply #17 on: November 01, 2011, 03:19:58 pm »
Dogee only needed the front diamond for his progect , so id say he would jump a it
Re: 1974 tm250
« Reply #18 on: November 01, 2011, 03:24:56 pm »
Fark what a mess... just attatch a chain it'll make a perfect anchor
Re: 1974 tm250
« Reply #19 on: November 01, 2011, 03:52:18 pm »
Mark, it is repairable.
I suppose the Titanic's repairable too Dave...but jesus, whoever did those mods should by law be prevented from using a hacksaw or welder for life. Over the years I 've found many frames that were butchered in the vain attempt to 'modernise' the rear end during the  '74/'75 suspension revolution but this is the absolute worst I've seen. Not only is the welding and pipe work on that 'conversion' beyond atrocious, the actual geometry of the changes are as wrong as you could ever get..easily seen by the stress bends in the gussets for the top shock mounts. It must have been a pig to ride (if it was ever used, that is). If all Dodgee needs is the front half I guess it'll do but surely anything would be better than that.
 I've got a '75 TS frame that's pretty straight if you can use it Dodgee.
TM BILL
Re: 1974 tm250
« Reply #20 on: November 01, 2011, 04:00:09 pm »
I think its been welded with a kids sparkler :)
Offline vmx42
Re: 1974 tm250
« Reply #21 on: November 01, 2011, 04:48:26 pm »
I think you are being a bit harsh.
I have it on good authority that Stevie Wonder, himself, modified it as a Tech project back in the 70's. Luckily he then found music and left motorcycle fabrication behind forever...
Re: 1974 tm250
« Reply #22 on: November 01, 2011, 05:10:19 pm »
I just looked at it again and I reckon a plumbers been there........how much alcohol do you think was involved there or was it weed man?.....a Cheech and Chong special....copied out of Dirt Bike magazine.....what more can I say?
TM BILL
Re: 1974 tm250
« Reply #23 on: November 01, 2011, 06:24:43 pm »
As a self confessed conisuier no self respecting stoner would be responsible for that  :o theres definetly alchohol involved in that project  ;) Mind you i think Jeffs onto it  :) a drunk Stevie Wonder  ;D
Offline suzuki27
Re: 1974 tm250
« Reply #24 on: November 01, 2011, 06:30:36 pm »
I think it could be a piece of Modern Art. After some of the s..t I have seen that passes for modern art, I can at least relate to the struggle  that this Artist went through . What he has done is not easy. It would take a massive amount of work to produce that end result. Maybe we need to set up a museum of modern art for vintage bike restorers. I know I have a couple of 'pieces' that didn't turn out the way I envisaged!!
Re: 1974 tm250
« Reply #25 on: November 01, 2011, 06:46:01 pm »
Proto-type GMC frame?....when he was 3 years old?.....I know he has "lost" all sorts of objects in the dam, maybe this one was reincarnated....the TM devil lives......maybe he made it when the Exorsist came out.....you know what they say about those country Victorians. ;D
Re: 1974 tm250
« Reply #26 on: November 02, 2011, 11:39:32 am »
Think they were going for the early Works deal..... cheap 75 model close out into the Rm
Offline huskibul
Re: 1974 tm250
« Reply #27 on: November 02, 2011, 12:16:28 pm »
       The only problem making an anchor out of it would be having to lift it back into the boat again and again and seeing those welds over and over - errrrh   i say leave the chain off it and help the world with a bit more of fish structure  :-*
monaro308
Re: 1974 tm250
« Reply #28 on: November 02, 2011, 12:32:25 pm »
Warning...do not read that quote when eating cerial  :D
I'd cut the rear section off and add a removeable sub frame to it and its good as gold  ;D
Where's your sense of adventure fellas
Plumber...no,he'd be out fishing in his gaylux and 50ft boat to mess with that.
Stevie...no,unless he can read the brail in those welds.
As an anchor it would kill our eco-system.
Offline vmx42
Re: 1974 tm250
« Reply #29 on: November 02, 2011, 04:01:39 pm »
I'm not so sure. I spoke to a friend who teaches blind kiddies to read Braille. He said he couldn't be sure without actually running his fingers over the welds, but he indicated that he is 99% sure it is "a cry for help".
He couldn't give me any more info, but he did say that the perpetrator was obviously a troubled soul who could by this time have worked his way into a CEO position in one of our major companies. I suggested Alan Joyce and he said I could be right as it is obvious that he has no ability to "see" reality.
I wonder...
