Author Topic: MX250 cdi  (Read 2374 times)
Offline steve7406
MX250 cdi
« on: September 27, 2011, 04:41:34 pm »
Looking for a hitachi cdi unit for my 75 mx250 or any other brand that will fit/work.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Re: MX250 cdi
« Reply #1 on: September 27, 2011, 05:28:37 pm »
EBAy - they just keep coing up.
125/250/360/500 will all work, just the plugs change to more or less.
Re: MX250 cdi
« Reply #2 on: September 27, 2011, 08:58:23 pm »
Offline steve7406
Re: MX250 cdi
« Reply #3 on: September 28, 2011, 12:33:40 pm »
Thanks Freakshow have made contact with seller .
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline asasin
Re: MX250 cdi
« Reply #4 on: September 28, 2011, 01:52:04 pm »
I have just sucessfully put a KT 250 one on mine , it works well
If in doubt ,WIND IT OUT
Offline steve7406
Re: MX250 cdi
« Reply #5 on: September 28, 2011, 08:18:48 pm »
asasin whats the availability on those units and is it hard to adapt.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline asasin
Re: MX250 cdi
« Reply #6 on: October 01, 2011, 07:02:19 am »
KT 250 ignition cdi was easy to find  and I was able to use a MX/DT pickup and rotor on the motor ( that bit was a bit hard to find) if you have a electo sparky or tech friend the hookup is not too hard, I can give you a drawing if you end up with these parts
 It is on a YZC 250 motor , gives it good low end response and gets the timing out before pinging in mid range
« Last Edit: October 01, 2011, 07:04:24 am by asasin »
