Author Topic: 1976 yz 250 bottom end / engine covers  (Read 1732 times)
Offline steveo247
« on: August 08, 2011, 07:53:57 pm »
looking for a bottom end for a yz 250 C. The crank can be stuffed, i have a good crank to go in it. I mostly need the gearbox and the crankcase covers all 3 of them would be very handy.
contact on here is easiest for me!
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 1976 yz 250 bottom end / engine covers
« Reply #1 on: August 09, 2011, 12:36:46 am »
i may have a clutch cover and some gearshafts but won't get a chance to check the shed till thursday.
remind me if i don't get back to you before then.
Vandy :)
"flat bickie"
Offline steveo247
« Reply #2 on: August 10, 2011, 08:37:19 pm »
scored a clutch cover off ebay for $12 !
thanks anyway vandy. if you had the other side covers would be awesome.
Offline vandy010
« Reply #3 on: August 12, 2011, 11:53:05 am »
just checked the shed Steve,
no magneto or sprocket covers.
have both gearshafts with a heap of munched/broken cogs,
countershaft appears slightly bent,
so that leaves only the front gear shaft that'd be of any use.
not much help i'm afraid.
Vandy.
"flat bickie"
IT400C
« Reply #4 on: August 12, 2011, 12:47:06 pm »
I may have a flywheel cover spare - I'll check on the weekend
Sprocket cover?   What condition do you need?  I may have an old one of these too, but probably only a broken or repaired one - at least 50% of the second hand ones have the piece that runs inside the chain broken off (first time the chain comes of they're gone..)
